ᐅ Are there alternative handles available for the standard fittings of Pax?
Created on: 3 Feb 2023 09:17
Gibau31
Hello everyone, I am currently looking into whether there are alternative handles to the standard fittings for Pax wardrobes. The Ikea Pax wardrobes are quite common and come with solid standard handles, but I often find them a bit plain and lacking individuality. My question is: Are there practical and visually appealing alternatives to the standard handles of Ikea Pax that are easy to install, possibly priced similarly, and still enhance the character of the wardrobe? I would be very grateful if you could share your experiences or recommendations—whether related to your own modifications, specialized suppliers, or DIY solutions. Thanks in advance for your input!
Gibau31
3 Feb 2023 14:05
Thanks in advance for the suggestions! I find the idea of leather or rope handles especially interesting—it sounds like a very unique look.
PeoDaniel schrieb:
DIY solutions where you design and attach the handle elements yourself
Could someone explain in more detail how these DIY modifications work? Is it easy to do on the Pax cabinet frame? It’s important to me that the handles not only look good but are also functional and sturdy—I don’t want to risk damaging the wardrobe. Maybe you have some tips on what to watch out for?
Ethan
3 Feb 2023 15:40
DIY handles are definitely possible, but there are a few important points to consider:
- The material must be strong enough to withstand constant tension (e.g., leather with proper eyelets or securely fastened metal rings).
- The hole spacing should match the Pax pre-drilled holes to avoid needing to drill additional holes.
- Installation should be done carefully to prevent damage to the cabinet, meaning no frayed or unstable drill holes.
Many users, for example, attach leather straps with decorative screws to the existing holes or use handles made from cords or ropes with a firm core. It is important that the attachment is not too loose.
Leote
4 Feb 2023 08:56
For those who prefer something simple and sturdy: stainless steel handles are a good option. They are very durable and visually suit almost all interior styles. Just measure the hole spacing and look for suitable handles at the hardware store. Easy to replace.
Thierryzar
4 Feb 2023 12:33
Some time ago, I installed alternative plastic handles that are lighter compared to standard handles and have a good feel.
Ellis schrieb:
Are there any specific recommendations for models that are particularly durable or robust?
From my experience: plastic handles are durable, but their appearance doesn’t always match a high-quality look. If you want something more premium, you should stick with metal or wood.
nonlau35
5 Feb 2023 07:42
Summary: There are many alternatives; as long as the hole spacing is correct, almost all handles will fit. Leather, wood, metal, plastic – depending on taste and use. Just try them out.
