ᐅ Are there alternative handles available for Malm drawers?
Created on: 3 Mar 2022 08:37
BAUFRA
BAUFRA
3 Mar 2022 08:37
Hello everyone, I have a question that many might have wondered about: Are there alternative handles for IKEA Malm drawers that are easy to install, don’t significantly alter the design, and are durable at the same time?
I want to replace the standard handles because I don’t like how they look and find them somewhat bulky. However, I have no idea if there are compatible alternatives that fit without much effort. Maybe someone has experience or tips on suitable handles or even tricks on how to operate or open the existing drawers differently. I am especially interested in mechanical solutions that don’t require drilling or are at least less labor-intensive.
sarGabriel
3 Mar 2022 09:15
Yes, a simple alternative is clamp handles or self-adhesive handles that you stick onto the front. They require no drilling and are quick to install. However, pay attention to their durability with daily use.
Friedrich
3 Mar 2022 11:42
I sympathize with your wish to customize the Malm drawers a bit, as the standard handles also seem rather functional to me. Some time ago, I tried to adapt screw-on handles from a hardware store but was unsure about the drilling holes. It can be a bit frustrating when you are looking for a nice solution, but the installation requires more effort than expected. How important is the original piece of furniture to you—do you want to keep the handle hole pattern as intact as possible?
kogudra
3 Mar 2022 14:03
Friedrich schrieb:
How important is the original piece of furniture to you? In other words, do you want to preserve the pattern of the handle holes as much as possible?
This question is crucial because Malm drawers often have pre-drilled holes that need to be taken into account when changing handles. If you don’t want to drill new holes, you can choose handles with screw distances matching the existing holes. Alternatively, you can install so-called “handle bars” or furniture strips that stick onto the front and serve as handles, which require no new drilling for installation.
I also recommend paying attention to the handle projection to ensure it doesn’t limit usability, especially when furniture elements are placed close together.
fikeo
4 Mar 2022 07:29
The question of alternative handles for Malm drawers is truly an interesting challenge. There are basically three options: classic screw-on handles, clamp or clip-on handles, as sarGabriel already mentioned, and thirdly, handleless alternatives.
Handleless solutions often involve push-to-open mechanisms or recessed grip grooves that can be retrofitted. However, these usually require more installation work and sometimes modifications to the drawer front.
If you only want to change the appearance without major work, self-adhesive leather pulls or metal strips might be a nice option. They are relatively durable and have a modern look. It is important to measure the screw distances carefully if you are screwing them on or to check the adhesive quality if you use adhesive options.
Tinaneo
4 Mar 2022 09:53
sarGabriel schrieb:
A simple alternative are clamp handles or self-adhesive handles
This recommendation makes sense, but I would question whether the durability remains stable in the long term, especially for furniture subjected to higher loads. Clamp handles can loosen over time, and self-adhesive solutions depend heavily on the quality of the surface they are attached to.
Another point that is rarely mentioned is the ergonomics of the handle: Some alternatives may look good but are uncomfortable when opening drawers, particularly if there are children or elderly people in the household.
Are there any experiences here with specific handle models that are convincing not only visually but also functionally?
