ᐅ Are the solar panels and wiring installed according to the relevant standards and regulations?
Created on: 9 Nov 2020 05:02
marco2403
Our installer started mounting the solar systems and thought that while the scaffolding was still up, he could finish the roof work, such as solar wiring, roof ventilation, and exhaust pipes.
Now, without informing me, he has already installed the drain pipes.
My questions are: Do the cables from the solar system to the house also need to be insulated? Is the penetration through the roofing membrane compliant with standards? Is fastening the solar cables to the roof structure using cable ties according to regulations? Is laying the drain pipes on Styrodur (extruded polystyrene insulation) compliant with standards?
Additionally, I informed the installer that I would like all exterior walls to be plastered, even if they are shuttered. He replied that the plasterer would surely be able to work behind the pipes.
What would you do in my situation?
Close-up of roof tiles with fastening clamp at the roof edge
Insulated pipe lying on concrete floor, construction accessories nearby; stacks of bricks in the background.
Shell bathroom: white toilet frame, drain pipes and water lines on wall and floor.
Basement construction site: concrete wall with holes, insulated pipe running on the floor, wooden batten on the right.
Basement attic with sanitary installations: white flush tank pump module and installed pipes.
Wood frame on left, black folded material with cable tie and yellow star sticker.
Construction site: piping with wall frame for toilet in unfinished room.
Small unfinished bathroom with wall-mounted flush tank, visible pipes and shell walls.
Wood beams over dark surface; yellow warning tape around a black object with cable tie.
Roof structure with slanted wooden beams inside, dark background, visible cables
seat8810 Nov 2020 17:09
marco2403 schrieb:
Is it also recommended to insulate the drainage pipes with Styrodur?
Sure, the screed will be poured around them anyway.
