I would like to start a focused discussion: Are the Ikea Brimnes cam locks and the supplied screws actually a common problem in the assembly and durability of the furniture?
I have noticed that many users complain about loose joints or screws that loosen quickly, especially with the Brimnes products. Specifically, I am interested in whether there are any design-related weaknesses in these fasteners – for example, are the screws of poor quality or too short, or is it more a matter of the cam locks not gripping the wood sufficiently?
The type of materials used and how they interact with the screws could also be a factor. Does anyone have experience with this or even suggestions for improvements? Perhaps alternatives could be recommended if the original parts are indeed often the bottleneck.
manlau schrieb:
Are the Ikea Brimnes sockets and the included screws actually often the cause of problems during assembly and durability of the furniture?I think it is too general to blame the screws and sockets in all cases.
First, it would be necessary to clearly define what “the problem” exactly means: looseness, material fatigue, or assembly errors? Are the screws too short? Do they not grip properly?
Often, a problem also arises from improper assembly or missing pilot holes, which IKEA itself might recommend.
Furthermore, there is a lack of reliable data on how often these parts fail. Where does the assumption come from that the Brimnes units are more frequently affected?
It is important to consider both product quality and user behavior before drawing any conclusions.
I can add some factual information to the discussion:
Ikea often uses particleboard with a melamine coating for the Brimnes furniture, along with relatively thin connection points, which can be mechanically quite demanding.
The sockets are typically made of zinc die-cast, which is generally sturdy but sensitive to over-tightening or incorrect screw angles.
The supplied screws are often self-tapping and not particularly long, designed to avoid compromising the strength of the thin panels.
These characteristics can lead to problems if assembly instructions are not followed precisely or if the furniture is frequently moved.
In short: the fasteners are optimized for the choice of materials and cost, but combined with the composite materials and usage, they can become critical points.
CARLA schrieb:
Ikea often uses particleboard with melamine coating and relatively thin connecting joints in the Brimnes furniture, which can be mechanically quite demanding.That is a relevant point.
I would add that the furniture industry generally faces a trade-off between low production costs and durability.
Especially with budget models like Brimnes, compromises have to be made in material thickness and quality, particularly in fastening elements.
Hector schrieb:
Problems often arise due to improper assembly or lack of pre-drilling, which IKEA itself could recommend.This should not be underestimated either. Poor assembly leads to failure more quickly than the quality of the screws alone.
Overall, this is probably not a general quality problem with the sockets/screws, but a complex interplay of material, design, and assembly.
