ᐅ Any tips for transporting multiple KALLAX units at once?
Created on: 11 Mar 2022 17:23
lamatthi68
Hello everyone, I am planning to transport several IKEA KALLAX units at once soon and want to do so in a way that is both gentle on the materials and practical. Does anyone have experience or tips on the best approach? Specifically, I am interested in how you secured the units together, whether you used any special tools (e.g., lifting straps, strapping bands, dollies) and what to watch out for when carrying and loading to avoid scratches or damage. Tips on the maximum recommended stacking height or protecting the edges are also welcome. I would appreciate various suggestions, including the pros and cons of different methods.
Laurence
12 Mar 2022 08:59
Especially when you want to move several KALLAX units at the same time, careful preparation is important. I recommend the following steps: First, place spacers made of foam or cardboard between the units to prevent pressure marks. Then wrap furniture blankets or thick blankets around them, especially on the corners and edges. Ratchet straps provide secure fixation, but be careful that the edges of the straps don’t act like cutting tools – using a small edge protector can help. In the vehicle, lay the units as flat as possible in the cargo area and secure them against shifting. One more tip: avoid stacking them too high, as the weight could damage the lower units.
Z
zarlu
12 Mar 2022 11:12
sarla schrieb:
For securing, textile strapping bands made of polypropylene are suitable, which can be firmly fixed with tension locks without damaging the paintwork.
Sure, that's technically clever, but honestly: isn’t that a bit much for most moves? I mean, the KALLAX units are pretty sturdy, and personally, I find the effort to wrap and strap them so meticulously rather a waste of time. Better to have two people carefully carry them. Anyone with a hand truck or dolly has a clear advantage anyway.
“Maximum protection” can also become overkill and end up complicating the whole process. Just my blunt opinion on the matter.
gadalu
12 Mar 2022 13:05
From a practical standpoint, the following guideline applies: KALLAX units should be emptied before transport. To avoid scratches, it is best to use furniture blankets or bubble wrap, especially on the edges. Securing with strapping systems is ideal for a safe hold, particularly for bulky loads. For loading the vehicle, trolleys or pallet jacks with non-slip surfaces are suitable. However, stacking more than 2 units high is not recommended from a structural perspective. The weight may cause strain and damage.
lamatthi68
12 Mar 2022 16:26
Thank you for the many helpful and varied tips! The advice about protective padding and strapping bands especially makes sense to me.
zarlu schrieb:
Sure, that’s technically smart, but honestly: Isn’t that over the top for most moves?
You’re right, sometimes I tend to over-organize. But better to be well prepared once than to regret it later.
Does anyone have experience with foam edge protectors? I ask because I’m concerned whether even thin foam cushions provide enough protection under heavy load. Or would a special edge protection profile (made of plastic or rubber) be more effective? I would really appreciate any specific product recommendations.
bauku
12 Mar 2022 18:12
lamatthi68 schrieb:
Does anyone have experience with foam edge protectors? I’m asking because I’m concerned whether even thin foam padding provides enough protection under heavy load.
I can tell you from my own experience: yes, foam edge protectors are great! I bought these corner covers that you slip over the edges like small sleeves. They are sturdy and flexible, not too thick, so the modules are still easy to carry. The best part: combined with furniture blankets on the outside, everything stays very well protected. During my last move, I didn’t get a single scratch. It’s important, though, that the pads fit properly and don’t slip.
If you plan to stack the modules multiple times, this is definitely the way to go! Good luck, you’ll manage it :-)
