ᐅ Any tips for transporting multiple KALLAX units at once?
Created on: 11 Mar 2022 17:23
lamatthi68
lamatthi68
11 Mar 2022 17:23
Hello everyone, I am planning to transport several IKEA KALLAX units at once soon and want to do so in a way that is both gentle on the materials and practical. Does anyone have experience or tips on the best approach? Specifically, I am interested in how you secured the units together, whether you used any special tools (e.g., lifting straps, strapping bands, dollies) and what to watch out for when carrying and loading to avoid scratches or damage. Tips on the maximum recommended stacking height or protecting the edges are also welcome. I would appreciate various suggestions, including the pros and cons of different methods.
bauku
11 Mar 2022 18:47
Oh, this is a great topic! 🙂 A few months ago, I transported three KALLAX units at the same time and can definitely recommend padding the units first with furniture blankets or old blankets. Then I secured everything tightly with ratchet straps – this holds everything firmly and prevents scratches from shifting! It’s important not to tighten the straps too much, as this can cause pressure marks. And very important: lift the units with two or three people if possible, to avoid back injuries and damage. Good luck, you can do it! :-)
sarla
11 Mar 2022 19:12
For better transport organization, I recommend measuring all modules precisely first. The standard KALLAX modules generally have a compartment size of 42x42 cm (16.5x16.5 inches) and come in various heights. To stack the modules safely, the maximum allowable load must not be exceeded – according to IKEA’s specifications, KALLAX modules should not be stacked too high to maintain stability. Textile strapping bands made of polypropylene are suitable for securing, as they can be tightened with tensioning closures without damaging the finish. When transporting on a rolling cart, it should be equipped with a non-slip surface to prevent slipping. Wrapping with stretch film offers additional protection.
rickey
11 Mar 2022 20:02
I think it’s great that you’re approaching this topic so carefully and thinking about protection. When I moved last time, I also didn’t secure things well enough and unfortunately ended up with a few minor scratches on the edges.
bauku schrieb:
Lift the panels in pairs or threes if possible to avoid back problems and damage.
I can only agree with that! When carrying, just move carefully—don’t drop or let them fall onto hard floors. Maybe the tip to empty the panels beforehand, if there’s still something inside, could make carrying more comfortable. Have you considered using a protective mat? Especially on stairs or in a vehicle cargo area, a lot can go wrong.
LEEJU
12 Mar 2022 06:33
Use tie-down straps, cushion the modules, never carry them alone, and stack no more than two on top of each other.
islaron
12 Mar 2022 07:45
Trolley for transporting items within the house, with straps on the outside and blankets for protection. Secure edges with tape.
