ᐅ Frost Protection in the Heating Circuit: Preparing a Vacation Home with a Gas Boiler for Winter?
Created on: 4 Jan 2026 21:29
Authentic1A
Authentic14 Jan 2026 21:29Good day,
this concerns a small holiday home with 4.5 rooms in northern Italy. It is heated by a Vaillant boiler (liquefied petroleum gas) and aluminum radiators, which are connected using copper pipes (entire installation from 1995). The recently renovated bathroom has plastic pipes and a standard radiator (not aluminum).
Is there any reason not to add antifreeze to the heating circuit? The house is usually unoccupied during the winter. Leaving the heating running is not an option. Or is it unavoidable to drain the heating water each time? The drinking water is drained anyway.
Thank you very much
Thank you very much
Hi,
using antifreeze in the heating circuit is an idea that looks reassuring on paper but has a few drawbacks in practice, especially for a system from 1995. In principle, there is nothing against it, but only if the antifreeze is explicitly approved for heating systems and remains compatible with aluminum, copper, and the seals of the Vaillant boiler. Otherwise, after a few winters, you’ll end up with sludge rather than protection in the system. Many also underestimate that antifreeze reduces heat transfer and increases viscosity, which the pump will silently but steadily dislike. Completely draining the system every year is also not an elegant solution, as oxygen ingress accelerates corrosion, which usually only becomes visible after 8 to 10 years. In northern Italy, with occasional temperatures around -5°C (23°F), a well-adjusted frost protection operation of the boiler, if available, is usually sufficient, but you already excluded that. Mixing aluminum and steel components is sensitive anyway, so I would look at that very carefully.
