ᐅ AMMERÅN Utility Sink
Created on: 7 Feb 2017 08:07
Alme
Alme
7 Feb 2017 08:07
After water damage to my 15-year-old but otherwise intact Faktum kitchen with Nexus birch veneer fronts (partially swollen countertop, damaged sink cabinet), I am considering designing a sink module. This would save me a long wait for a 2.86 m (9 ft 5 in) long countertop. I could take ready-stock countertops directly from IKEA and build the module in between. I have the AMMERÅN surface-mounted sink in mind. Although it was designed for Metod, with appropriate adjustable plastic feet, it roughly matches the Faktum countertop height.
I also have a new Faktum sink cabinet plus front as an alternative. I was told that the AMMERÅN might even be mountable on it. In theory, I can try this out beforehand.
My question: does anyone have experience with the AMMERÅN sink? Or any other good renovation suggestions?
IKEA-Experte
7 Feb 2017 21:05
Why don’t you just wait the few weeks until the custom countertop is delivered for the swollen board?
Have you checked the delivery time at the hardware store?
Alme
8 Feb 2017 09:12
I want to have a functional kitchen as quickly as possible. After replacing the corner valves, the sink has already been removed. The countertop was cut into two parts and dismantled.
I thought Ammerån would be a quick and stylish solution. I like large sinks.
The worktops from the DIY store that I like have a depth of 60cm (24 inches), which is not the right size for Ikea base cabinets. You would need to create a kind of 2cm (0.8 inch) recess behind them. I had a quote made, which came to just over 700 euros, including removing the old countertop and reinstalling the new one. The estimated waiting time for the contractor’s service is about 4 weeks.
fleptin
8 Feb 2017 11:05
If you like the sink, that is definitely a great solution.
At Bauhaus, there are solid wood countertops with a depth of 63.5cm (25 inches) available (depending on the store, sometimes in stock) and laminate countertops with a depth of 90cm (35.5 inches) as special order items (Resopal, approximately 2 weeks delivery time). Hornbach also offers laminate countertops in 63.5cm (25 inches) depth from Kaindl, partly in stock.
Carpenters working with countertops from Egger or Kaindl can also cut a countertop to 63.5cm (25 inches) depth for you. (Although I believe Factum countertops only had a depth of 62.5cm (24.5 inches).)
IKEA-Experte
8 Feb 2017 15:42
In hardware stores, you can order custom-sized panels for any depth. Installation can also be done by someone else. Carpenters can order and install countertops as well. Whether 700 € is a lot or a little depends on the material of the countertop.
I wouldn’t like AMMERAN because there would be a silicone joint on the sides of the countertop, which is hard to keep looking good over time.
Alme
10 Feb 2017 17:28
Thanks for your tips! I’m excited and definitely need to check it out.
I had also considered Resopal. At first, I wasn’t very fond of it. But it seems to be excellent in quality.
If I can still use the current kitchen for another 5-6 years, that’s fine. So I could also live with the silicone joint. After that, everything that is still usable will be moved to the garden shed, and I can calmly plan a new kitchen.
