who here has aluminum roller shutters, possibly in a specific color?
For example, matching the window frames, blinds, front door, or garage door?
You often see colored surfaces between windows that create the effect of a continuous band. But when the roller shutter is lowered on such a colored band, and the very attractive gray of a plastic roller shutter appears, it no longer looks as nice.
Some blinds, which are also made of aluminum, are often seen with anthracite-colored slats, for example. So why not have that option for roller shutters?
Best regards!
Best regards!
nordanney7 Sep 2015 14:16You can choose the roller shutter slats in almost any color you like. This may involve an additional cost. In our building area, everything from white to light gray and anthracite is available. It does not matter whether the material is aluminum or plastic.
Sebastian797 Sep 2015 14:25I would avoid using dark-colored plastic...
I wouldn’t use a roller shutter in anthracite at all... the component can easily reach 90°C (194°F) when exposed to sunlight and might warp in the worst case.
Bautraum2015 schrieb:
I wouldn’t use an anthracite roller shutter at all... the part easily reaches 90°C (194°F) in sunlight and can warp in the worst caseHave you experienced this yourself?
Not me, but our immediate neighbors. I will ask them at the next opportunity which material they used. Their south-facing side was/is completely warped.
