ᐅ Aligning Drawer Fronts on an Ikea Faktum Kitchen Base Cabinet
Created on: 13 Mar 2009 06:55
Biene
Biene
13 Mar 2009 06:55
Hello everyone!
I bought a Faktum kitchen. It includes a base cabinet with 5 drawers, the bottom one being slightly larger than the others. My problem is that I can’t get the drawer fronts aligned properly, I’ve tried everything. The gap between the bottom drawer and the one above is simply too large. Also, the drawer protrudes downwards a lot. Oh dear, I hope I explained myself clearly enough 😕
Can someone help me?
Thank you!
Best regards, Biene
PaulKlee
15 Mar 2009 12:09
Hello Biene,
try turning the bottom drawer front around! The brackets screwed onto the drawer front are not centered, so you have a smaller gap on one side and a larger gap on the other. You can easily remove the front with a screwdriver from the side (under the Ikea flap).
Regards
Paul
Biene
15 Mar 2009 19:31
Hey dear Paul, THANK YOU for this great tip! Why keep it simple when it can be complicated *laugh*.
BUT: I can’t get the front off. Behind the flap, there are only two plastic screws for adjusting the height and, uh, well... left/right.
And now? The plastic screws are already a bit damaged after my "treatment". 😳
Best regards, Biene
Biene
17 Mar 2009 10:07
So, I ended up removing the front after all. Unfortunately, flipping it doesn’t help. I will probably have to drill new holes.
Best regards, Sabine
moppe
19 Apr 2009 19:01
Then better check the alignment of the rails.
