I have the following problem: We want to build a KfW house with an air source heat pump. Now the builder says the air source heat pump cannot be installed because the development plan requires it to be enclosed. Are there air source heat pumps that are not allowed to be installed without an enclosure? Should the builder have informed me about this?
That’s it for now... I hope to get some answers here.
Because the architect said it is not possible to build an enclosure around the air source heat pump. That was my question: are there air source heat pumps that are not allowed to be placed inside enclosures? Or is it generally the case that any air source heat pump, regardless of manufacturer, can be installed in an enclosure?
This concerns a Thermia iTec air source heat pump.
HilfeHilfe31 May 2020 21:00Better to avoid enclosing structures
Oh God! Air source heat pumps are generally built without an enclosure, which is related to airflow and does not require further explanation. The development plan cannot prohibit technical necessities -> discussion with the local authority/municipality. Otherwise, the system should be installed according to the manufacturer’s specifications, as only then is there a guarantee of trouble-free operation.
