ᐅ Air-to-water heat pump or gas heating combined with controlled ventilation in a 135 sqm single-family home?
Created on: 18 Apr 2018 19:29
M4rvin
Hi everyone!
We want to build a single-family house with about 135 sqm (1453 sq ft) without a basement. Originally, we planned to install an air-to-water heat pump (Dimplex, ELCO, or Viessmann), but we just learned that the plot has a gas connection. We had actually ruled out gas because we did not want to install an external gas tank. (But the outdoor heat pump unit isn’t very attractive either...) The developer would credit us €4000 for a gas condensing boiler plus a solar system with two flat plate collectors.
Is it also possible to skip the solar system and instead install a ventilation system with heat recovery? I would like to have ventilation, but €12,300 is too expensive for me!
We are leaning toward 17.5 cm (7 inches) calcium silicate blocks, but without extra cost, 24 cm (9.5 inches) calcium silicate blocks or brick would also be possible. (EDIT: pitched roof and underfloor heating)
Thanks in advance,
M4rvin
Thanks in advance,
M4rvin
Received the answer today:
"The detailed energy saving ordinance calculation is not yet available. We have only received from the energy consultant the statement that you can forgo the solar system if you choose the controlled residential ventilation. Once the exact equipment and the construction plans are available, he can prepare his calculation in detail. I would be happy to share the key figures with you then. At the moment, however, this is still not possible. Thank you for your understanding."
"The detailed energy performance calculation is not available yet. We have only received from the energy consultant the statement that you can forgo the solar system if you choose the controlled mechanical ventilation. Once the exact devices and the construction plans are available, he can prepare the detailed calculation. I can then share the key figures with you. Currently, this is not possible. Thank you for your understanding."It's a pity, but thank you for the feedback.
I once entered our house into an energy performance calculator including all the U-values and so on, and the result was that the Ht-value was about 15% below the current energy regulation requirement, but the annual primary energy demand for the combination of gas plus controlled mechanical ventilation without solar did not reach 15% below the current regulation requirement (due to the compensatory measure for the Renewable Energy Heat Act).
On the contrary, only the combination of gas plus controlled mechanical ventilation plus solar achieved an almost exact result just below the permissible maximum annual primary energy demand. Therefore, in my opinion, the combination of better insulation and controlled mechanical ventilation without solar would not qualify as a compensatory measure under the Renewable Energy Heat Act. A blower-door test would improve the result even more, but still not reach 15% below the 2016 energy regulation standard building.
Let's see what our energy consultant says.
I now suspect that the benchmark for the numbers posted by Alex85 (Qp 55% and Ht 70%) is the reference building of the energy regulation and not the current 2016 version requirements of the energy regulation (Qp of the reference building × 0.75, Ht of the reference building × 1.0, so no tightening here).
In that case, 55% of the reference building would still be an excellent result.
