Yes, OK, my calculation also assumes a maximum supply temperature of 30°C (86°F)...
What I'm interested in is the relationship between the supply temperature, room temperature, and outdoor temperature.
If a temperature difference is needed to heat the room to, for example, 20-21°C (68-70°F), then the supply temperature, regardless of the outdoor temperature, must be at least X degrees higher.
That’s why I’m wondering if, for instance, at an outdoor temperature of 5-10°C (41-50°F), the supply temperature must already be at least 24°C (75°F) for the room to reach 20-21°C (68-70°F)?
Then only 6°C (11°F) remain until the maximum supply temperature of 30°C (86°F) is reached, even though the difference between the standard outdoor temperature and the example 5-10°C (41-50°F) is 15°C (59°F) (difference between 10°C (50°F) and -15°C (5°F)).
I hope I was able to express myself clearly and didn’t make it too complicated?
T_im_Norden17 Nov 2020 20:09That depends solely on your house and its insulation values; no general figures can be given.
blackm88 schrieb:
Outside temperature currently 5.1°C (41°F), return flow 24.2°C (75.6°F), supply flow 24.4°C (75.9°F). Room temperature 22–24°C (72–75°F)Because it doesn’t hold steady during a cycle.
