Hello!
I'll start.
Heated area 200m2 (2,153 sq ft)
KfW 55 standard
Mechanical ventilation with heat recovery
Current outdoor temperature 6°C (43°F)
Heating energy consumption including hot water 35 kWh
Electricity consumption 9 kWh
COP 3.88
I'll start.
KfW 55 standard
COP 3.88
RotorMotor15 Nov 2021 19:34Isn't that already really little?!
Alright, it's fine already. My Lwz_5_s_plus runs minimally at 0.4kW at 20Hz when it's settled down.
I’m not familiar with yours, but since it's the same manufacturer:
- Maximum integral part
- Possibly reduce the proportional part
- “Heating design” set as low as possible (e.g., 50%)
- Design temperature as low as possible (max. NAT, or try minimum occasionally)
Dennis89 schrieb:
permanently at 25HzOr does that mean something non-modulating?KingJulien schrieb:
Yeah, that’s fine already. My Lwz_5_s_plus runs minimally at 0.4 kW at 20 Hz when it has settled down.
I’m not familiar with yours, but since it’s the same manufacturer:
- Possibly reduce proportional part
- “Heating design” as low as possible (e.g., 50%)
- Design temperature as low as possible (max. NAT, or try minimum sometimes)
Try and analyze 😉The design temperature is already set to -20. Unfortunately, I can’t adjust the other options.
KingJulien schrieb:
Or does that mean something is not modulating?It is modulating, but not below 25Hz. It could also be related to the outside temperatures since the heat pump has only been running since the end of October.
