ᐅ Air-to-Water Heat Pump: Current Consumption and Data
Created on: 29 Sep 2020 11:06
Bookstar
Hello!
I'll start.
Heated area 200m2 (2,153 sq ft)
KfW 55 standard
Mechanical ventilation with heat recovery
Current outdoor temperature 6°C (43°F)
Heating energy consumption including hot water 35 kWh
Electricity consumption 9 kWh
COP 3.88
Benutzer200
4 Nov 2021 22:52
Benutzer200 schrieb:
120 sqm (1,292 sq ft) older building from the mid-1960s – (still) no external thermal insulation composite system (ETICS), but the upper floor and basement ceiling are insulated. 75% of the windows are new.
Current energy consumption at around 22°C (72°F) indoor temperature is about 8 kWh including hot water, with nighttime temperatures of 3-4°C (37-39°F) and daytime temperatures of 7-9°C (45-48°F).
By the way, I don’t use any energy recovery ventilation (ERV) or actuators.
PeteHope
4 Nov 2021 23:55
Hello everyone 🙂,
I’m new to the forum, but I have been reading for some time to better understand my new heat pump heating system.
Since summer, we have also been using a heat pump to replace our old oil boiler. We are using it to heat our renovated and insulated old building. The energy consultant calculated a heating load of 11 kW (approx. KfW 60) for our house, and based on that, we chose (or rather, the builder recommended) the Vaillant Arotherm plus 125 A /S2. I am currently using the consumption and energy yield data recorded by the system. We do not (yet) have a dedicated heat meter or a separate electricity meter. We have exclusively underfloor heating. For hot water, we have a 300 L (79 gallon) storage tank and for heating, a 200 L (53 gallon) buffer tank. The system is running as expected and the house (176 m2 (1894 sq ft)) is as warm as desired (20-21°C (68-70°F)). Of course, the real test will be in winter.
Here are the system data for October.
As of 31.10.21; heating curve 0.6; flow temperature currently 28-37°C (82-99°F); domestic hot water 45°C (113°F)
702.6 heating energy yield / month in kWh
4.0 heating seasonal performance factor / month
225 electricity consumption / month in kWh
967 total heating energy yield in kWh
3.9 total heating seasonal performance factor
145.8 domestic hot water energy yield / month in kWh
2.5 domestic hot water seasonal performance factor / month
93 electricity consumption / month in kWh
459 total domestic hot water energy yield in kWh
2.7 total domestic hot water seasonal performance factor
Greetings from Bergisches Land
Alessandro
5 Nov 2021 08:20
This is already very good for operation with underfloor heating.
Alessandro
5 Nov 2021 08:24
OWLer schrieb:
By now, all rooms are almost at the desired temperature with these outside temperatures between 4-7°C (39-45°F). The WEK downstairs is still a bit too warm. But that doesn’t bother us since our loft door to the hallway/stairwell is still missing. Soon I can start turning off the actuators. Then there will be no more risks related to the bypass valve.
The heat pump ran perfectly the day before yesterday.
Today it was a bit warmer, and it is now cycling once per hour again.
This will still be a long journey. 🙂
That is absolutely normal for the transitional period.
Maybe you have the option to adjust the compressor output in the lower modulation range. With my heat pump, I can adjust the compressor output just like the heating curve. Of course, this is only possible in the technician settings.
OWLer8 Nov 2021 21:18
A somewhat silly question. I have now set the hot water to Eco mode so that the heat pump runs at a reduced capacity. The reason is that the heat pump is otherwise too loud for me when running at nearly 100% power. Unfortunately, there are no efficiency charts available across the modulation range. I would have assumed that the efficiency at 100%, with the high lift for hot water, is not optimal.
PeteHope
8 Nov 2021 23:07
I’ll join in on this question as well. I also think the heat pump doesn’t need to produce domestic hot water at nearly 100% efficiency. What are the pros and cons of Eco?
