ᐅ Air-to-Water Heat Pump: Current Consumption and Data
Created on: 29 Sep 2020 11:06
Bookstar
Hello!
I'll start.
Heated area 200m2 (2,153 sq ft)
KfW 55 standard
Mechanical ventilation with heat recovery
Current outdoor temperature 6°C (43°F)
Heating energy consumption including hot water 35 kWh
Electricity consumption 9 kWh
COP 3.88
Daniel-Sp
2 Jul 2021 10:25
We have a Novelan LICV 8, installed indoors, with a 300 liter (79 gallon) hot water storage tank. The circulation runs pulsed for about 2.5 hours per day. Two adults shower daily, and two children (6 and 8 years old) also shower daily during the summer. The hot water temperature is set to 49°C (120°F), with a hysteresis of 5K (9°F). Hot water is usually prepared once a day, rarely only every other day. Only occasionally does the younger child empty the hot water tank out of excitement. The heating system was not in use in June. Last year, during the summer months, we produced between 100 and 170 kWh of thermal energy for hot water preparation, so it was a typical month.
O
Oetzberger
28 Aug 2021 21:50
So, yesterday I turned the heating on again for the first time. I just like it comfortably warm inside the house. During the summer, the air-to-water heat pump stood out due to unexpectedly high standby consumption, with the monthly efficiency ratings falling to a poor 2.5. But I guess there's no way around that. Now the second heating season begins in the new house—I’m curious if the heat demand will actually be lower thanks to less construction moisture.
Is it already snowing at @Bookstar?
tomtom7928 Aug 2021 21:57
Why is there such a high standby power consumption? Have you investigated the cause?
O
Oetzberger
28 Aug 2021 22:08
This is a well-known issue with Alpha Innotec, where the oil sump heating continuously runs. According to the "rosa" forum, it apparently cannot be avoided.
halmi
28 Aug 2021 22:15
Our heating system has turned on again a few times over the past days, and it will probably come on again tonight.
nordanney
29 Aug 2021 00:28
halmi schrieb:
Our heating system has turned on again a few times over the past days; it will probably come on again tonight.
How cold is it where you are? My heating system hasn't even considered turning on yet, given the outside and indoor temperatures. And I haven’t even finished my energy retrofit...
