ᐅ Air-to-Water Heat Pump: Current Consumption and Data
Created on: 29 Sep 2020 11:06
Bookstar
Hello!
I'll start.
Heated area 200m2 (2,153 sq ft)
KfW 55 standard
Mechanical ventilation with heat recovery
Current outdoor temperature 6°C (43°F)
Heating energy consumption including hot water 35 kWh
Electricity consumption 9 kWh
COP 3.88
Bookstar
25 Apr 2021 17:06
We have everything in beige, which is very comfortable. Even in the height of summer, the terrace only gets pleasantly warm.
The heating now runs every other day for just a few hours. We should be finished soon...
4
4lpha0ne
25 Apr 2021 22:11
Bookstar schrieb:
You derive this from your offer? Is that your data basis valid for all of Germany? Seriously?
The assumption of 800 kWh/kWp is also not exactly valid across all of Germany.
But since with full feed-in (which nobody really recommends anymore) it’s more or less a break-even scenario, even a bit of self-consumption helps. Unless the electricity price drops below 0.08 €/kWh on average for the next 20 years.
Conversely, you can simply calculate at which kWp price you reach the break-even point:
Price_threshold = Yield_per_kWp_per_year * Feed-in_tariff * Tariff_duration
Yield_per_kWp_per_year is 800 or in other places rather 950+ kWh/kWp -> this can still be multiplied by a factor like 0.95 to account for the average yield over 20 years (degradation)
Tariff_duration is the 20+ years (the current year also counts, if I recall correctly).
4
4lpha0ne
25 Apr 2021 22:14
tomtom79 schrieb:
Since the topic often comes up regarding solar yield and which color the patio slabs should be
3 measurements on the subject
1x Tiles inside the house in anthracite behind the window
Do the panes still have a significant damping effect?
Bookstar
25 Apr 2021 22:33
What about the 70% maximum feed-in? Do you have to use 30% yourself?
nordanney
25 Apr 2021 22:52
Bookstar schrieb:
What about the 70% maximum feed-in? Do you have to consume 30% yourself?
There are different variations.
First of all, with the 70% limit, you don’t really experience significant losses because output above 70% is only reached at relatively few times.
Usually, the 70% is softly regulated. This means that a maximum of 70% of the system’s capacity is fed into the grid. If you have self-consumption before the grid connection point, you can of course draw power for that (at least the house’s base load). Hard regulation means that actually only 70% is passed on directly through the inverter ==> in reality, this means you lose about 5% of the annual yield with a good south-facing orientation. However, this saves you from buying a smart meter.
There are also solutions using ripple control receivers. However, these are not cost-effective for small systems due to relatively high expenses.
Z
Zaba12
26 Apr 2021 07:39
70% softness and good is fine. The normal base load, at least for me with 350-400 Wh, will never cover the peak. But there are enough appliances that can be run alternately around midday: washing machine, cooking, electric car, dishwasher, hot water, etc.
And this has only been the case since mid-April. It continues like that until mid-September. With the heat pump in heating mode, you don’t need to worry about this anymore.
