Hello!
I'll start.
Heated area 200m2 (2,153 sq ft)
KfW 55 standard
Mechanical ventilation with heat recovery
Current outdoor temperature 6°C (43°F)
Heating energy consumption including hot water 35 kWh
Electricity consumption 9 kWh
COP 3.88
I'll start.
KfW 55 standard
COP 3.88
Total electricity consumption in February was 901 kWh, which equals 32 kWh per day. This includes heating, hot water, and other electricity use (network cabinet, waterbed, etc.). Considering we had 1 1/2 weeks of extreme cold, I think that’s a good value. Currently, outdoor temperatures are dropping again, at 2°C (36°F).
We had an 11 kWh consumption yesterday, which is really impressive 😀. My wife hasn’t complained so far *phew, lucky me*.
The heating demand of the house is now only one-third of what it was before, with the heating curve adjusted from 28/21 to 26/20. I do not understand it, but I’m glad it is this way!
In February, we used 180m³ (about 6,350 ft³) of gas, but the heating was turned off for 3 days. The temperature was set to 24°C (75°F) and circulation was running continuously. Zaba would probably manage with less than 100m³ (around 3,530 ft³) of gas per month 😉 🙂
@Bookstar: compared to other heat pumps, your consumption is still quite high, isn’t it?
FF2677 schrieb:
We used 180m³ (6,355 cubic feet) of gas in February, but the heating was off for 3 days. The thermostat is set to 24°C (75°F) and the circulation pump runs continuously. Zaba would probably use less than 100m³ (3,532 cubic feet) of gas per month 😉 🙂
@Bookstar: But compared to other heat pumps, your consumption is still quite high, right? Well, not anymore 😀, it was too high before!
halmi schrieb:
The second part of February was really encouraging for photovoltaic performance again.
The heat pump usually starts at night and then runs until about 9 to 11 a.m., depending on how warm it gets. The past few days have been colder again, with energy consumption between 6–9 kWh.
There is still a lot of room for improvement in self-consumption when I compare my numbers with an 8.68 kWp system to yours. In this case, the difference is not due to the battery.
