Hello!
I'll start.
Heated area 200m2 (2,153 sq ft)
KfW 55 standard
Mechanical ventilation with heat recovery
Current outdoor temperature 6°C (43°F)
Heating energy consumption including hot water 35 kWh
Electricity consumption 9 kWh
COP 3.88
I'll start.
KfW 55 standard
COP 3.88
Malz1902 schrieb:
Unfortunately, my heat pump does not have a heat meter. The 24-hour consumption on 15.02 was 21 kWh. The 24-hour average temperature was +0.8°C (33°F) You just adjusted the temperatures yesterday, right?
I still don’t know exactly what you did. But if you only limited the maximum supply temperature at the top, then yesterday’s evaluation is basically useless.
Previously, you had been heating the screed with temperatures between 33 and 35°C (91 and 95°F). Now you limit the supply temperature to 30°C (86°F). However, the stored heat in the screed is still there.
halmi schrieb:
It’s alive!!! From now on, everything will get better 😀 It was rattling badly, then a third of the system became available.Here as well, for 1 hour now. Snow is falling off the roof. Unfortunately, the battery storage is still in standby mode. Starting tomorrow, it should start charging and supplying power.A
Alessandro16 Feb 2021 11:33Bookstar schrieb:
No worries, you can only lose against Zaba 😀.Then I’m all for kicking Zaba out of the thread due to unfair competition :p
