ᐅ Air-to-water heat pump combined with underfloor heating is not functioning properly
Created on: 22 Sep 2021 15:34
_
_Ugeen_
We moved into our single-family house in the middle of the year and are now using our air-to-water heat pump (Daikin Altherma 3 R ECH2O) for the first time. In the rooms, we decided against the standard analog controllers and chose digital controllers instead. After several discussions with Daikin and the controller manufacturer, I now understand that a valve is only opened or closed when I want to increase the temperature or not.
With the Daikin system, I can set a target room temperature. According to Daikin, this target value does not represent the minimum temperature per room but rather the "preheating value," if I understand correctly. This value was previously set at 23°C (73°F).
In the bedroom, I set the digital controller so that heating only starts when the temperature drops below 18°C (64°F). Despite this setting, the room temperature has always been 22-23°C (72-73°F), although the digital controller shows that heating is off. After changing the target room temperature from 23 to 21°C (73 to 70°F), it got a bit cooler. However, in the bathroom, heating is supposed to activate below 23°C (73°F). The temperature there is 22°C (72°F), and the digital controller indicates that heating is active. Yet, the room does not get warmer, and the floor heating does not noticeably warm up either.
Conclusion: I still have not understood the logic behind the target room temperature setting. In our previous apartment, we also had underfloor heating with analog controllers that I could adjust higher or lower. That worked wonderfully, and I felt like I could control the temperature. Here, with the air-to-water heat pump, I don’t have that feeling. Also, the towel warmers do not get truly warm (only lukewarm), which Daikin says is normal even when the dial is set to 5. This is apparently because it is a low-temperature heat pump. Without the electric booster to warm the towel warmers, they are essentially ineffective. Is this normal? Could there be an error, or do I need to use completely different settings?
If anyone has experience with this topic, I would greatly appreciate your feedback. At the moment, I feel a bit lost on this subject.
Alessandro
7 Oct 2021 09:08
I just quickly skimmed through the datasheet. It definitely includes a heating water buffer tank and a mixing group. Now it depends on the settings... Unfortunately, I couldn’t find a user manual or any information about the functions of the Daikin.
_
_Ugeen_
7 Oct 2021 13:12
So, we have a Daikin Altherma 3R ECH2O.
So far, we have only adjusted the target room temperature. To me, all rooms still feel equally warm, even though I have set one room not to be heated.
tomtom797 Oct 2021 13:14
Is it normal in a thermal envelope
_
_Ugeen_
7 Oct 2021 13:20
Even if I set a room via thermostat so that it should not be heated, can I then only adjust the air volume flow in the individual rooms to regulate the temperature? I find that quite complicated. District heating was definitely more convenient.
Daniel-Sp
7 Oct 2021 13:27
Familiarize yourself with hydraulic and thermal balancing, then you will understand what is feasible. Temperature differences between rooms with closed doors are possible within certain limits.
Tolentino7 Oct 2021 13:32
It may seem more practical at first, but in the end, it’s a bit like always pressing the accelerator fully and controlling the top speed only with the brakes. - Inefficient
