ᐅ Air Supply for Open Fireplace
Created on: 19 Sep 2017 14:00
DerRoman
DerRoman
19 Sep 2017 14:00
Hello fellow homebuilders and renovators,
My wife and I bought a house built in 1978 in the winter of 2016. Over the past winter, we made a lot of renovations, so the fireplace, located in the basement living room, has never been used.
We live in a valley with gloomy weather, and the neighborhood often smells like burning wood — and naturally, we would like to use our fireplace as well.
However, since I have only ever rented apartments without fireplaces before, I need to get familiar with the subject.
I understand that a fire requires a lot of oxygen and that combustion should be as complete as possible to avoid harmful gases.
I bought a CO detector and, after some research, lit a small fire.
It worked pretty well: the flame burned bright yellow, then turned blue, the wood burned completely, and in the end, only ash remained, falling through the grate into the ash pan.
So far, so good. But I noticed that adjusting the air supply doesn’t seem to make any difference. There are three “levers” on the fireplace. One obviously opens the flue to the outside; this lever is inside the firebox. Two other controls are located below the fireplace. One supposedly opens room air, and the other “bottom” air. To explain: In the basement, directly under the fireplace, there are two holes. Through one, ash seems to fall (there is a metal ashtray here), and the other appears to draw in air (a simple hole in the ceiling, apparently leading straight to the fireplace).
On both sides of the fireplace, there are openings in the casing. Air is obviously supplied here.
For me, the following is clear: Left lever controls air from “below.” Right lever controls room air.
Now my problem is: I don’t know which lever position means “open” or “closed.” Is it like water valves? Turn left: open — turn right: closed?
No matter how I set the levers, the flame always burns the same, and the amount of smoke doesn’t change.
The second problem: The fireplace burns nicely, but it produces hardly any heat. Granted, I only loaded it with two fitting logs, but only right in front of the fireplace was any warmth noticeable. The flame was strong, but the fireplace was far from heating the living room by a few degrees.
Unfortunately, I can no longer contact the fireplace manufacturer, as it no longer exists.
Maybe you can give me some advice. The chimney sweep will come in November, and I plan to ask him as well.
Fireplace made of red bricks with metal grate and dark interior; screwdriver lies at top right.
Corner made of red bricks with dark opening next to white wall.
Interior of a smoky grill with ash, soot, and a metal handle on the side
Narrow brick and concrete passage, right white wall; dark passageway at the back.
Close-up of a light brown brick wall with gray mortar and two curved metal handles.
Pink installation manual booklet for fireplace heating technology with logo and text.
Exploded view drawing of a fireplace stove with parts and numbers
berny20 Sep 2017 06:36
Open fireplaces rarely provide measurable warmth to the room; they are mainly for aesthetic purposes. Have a fireplace insert installed, and then it will also heat the room...
Kaspatoo25 Sep 2017 10:06
Is your fireplace open at the front without a glass panel?
Then it always gets air. It seems you can only control where the air comes from.
So you can’t suffocate it. Such fireplaces don’t actually help generate heat. Unless they burn so strongly that the stones heat up, but that’s not efficient.
An insert like that sounds interesting.
