ᐅ Air intake in a light well?
Created on: 7 Aug 2016 12:52
daniels87
we will install a ventilation system from Pluggit, which will be located in the basement.
The supply and exhaust air are planned to be routed through an opening in the basement wall that ends in a small light well. Is this a feasible approach? I am a bit concerned about the supply air coming in below ground level.
Also, it seems to me that the supply and exhaust air openings are quite close together.
Are there any regulations or guidelines that the construction company must follow regarding this?
Good luck,
daniels87
2D floor plan of a building with walls, doors, and building services, dimensions
daniels87
10 Aug 2016 08:09
The problem is that the wall penetration in the basement is located very high up. If there needs to be a slope, there isn’t much room to work with.
Sebastian79
10 Aug 2016 08:10
Then just install them a bit lower down.
daniels87
10 Aug 2016 09:06
There are already openings, but if it’s unavoidable, new ones will have to be made.
tomtom7910 Aug 2016 10:24
And preferably far away from it, in a cool spot to draw in the air.
daniels87
10 Aug 2016 10:54
Is a long pipe not problematic from a hygiene perspective?
Is a standard PVC waste pipe sufficient for this?
Sebastian79
10 Aug 2016 11:16
If any, then KG – HT pipes are not available in these sizes and should not be used underground.
