ᐅ Use an Air Source Heat Pump or Gas and Solar?
Created on: 11 Jul 2012 19:15
gigi
We are starting to get really frustrated... every builder tells us something different...
We want to build a 130sqm (1,399 sq ft) KfW 70 house with the living room facing south, and we are unsure whether to choose gas or an air source heat pump. Some providers, at almost the same price level, offer us air source heat pumps and claim that the annual costs are significantly (30%) lower compared to gas, while others doubt this.
We understand that insulation with gas/solar systems is usually better because an air source heat pump boosts efficiency more towards KfW 70 standards compared to gas/solar, which might argue in favor of gas. An air source heat pump might fail somewhat sooner, and in case of problems, you can usually get quick and competent local support with gas. With air source heat pumps, there could be more difficulties. Additionally, the noise of air source heat pumps (in our case about 3 meters (10 feet) from the neighbor) is not insignificant. Some say that sooner or later, everyone ends up having issues with neighbors for this reason.
We are interested in air source heat pumps with storage tanks from these providers: Vaillant, Mitsubishi Zubadan, and Rotex.
What we are really curious about is the annual cost for heating and hot water with both systems.
We live near Kassel.
What should we choose, and what would be cost-effective TODAY? What is your opinion on Vaillant?
Regards
Gigi
R.Hotzenplotz
7 Jan 2018 18:36
What kind of building envelope?
blackm887 Jan 2018 19:05
In the thermal envelope of your building. Or are your basement rooms insulated on the inside against the corridor, for example? Or does your basement have continuous external insulation all around, as well as under the slab?
R.Hotzenplotz
7 Jan 2018 19:07
The basement has perimeter insulation. There is no additional insulation between the rooms. However, we explicitly discussed and contractually agreed that only two specific rooms in the basement are heated, not all of them.
blackm887 Jan 2018 19:13
Yes, then all basement rooms are included in the calculation. It’s about the heat loss of the house to the outside temperature. It’s the same for us: hallway and hobby room are heated, the rest is not.
R.Hotzenplotz
7 Jan 2018 19:14
Nevertheless, they marked it incorrectly in the heating load calculation. The rooms simply do not have underfloor heating. Of course, the result of the calculation can still be correct.
Now I hope that tomorrow I get a competent energy consultant who can quickly verify the calculations for me.
blackm887 Jan 2018 19:17
I don’t see it that way. But maybe others can weigh in on this.
