ᐅ Air Source Heat Pump Electricity Meter!?
Created on: 5 Dec 2016 17:00
Horsti
Horsti
5 Dec 2016 17:00
Hello, our air source heat pump will be installed soon. An electricity meter is already in place.
Do I need to have an additional meter and a separate electricity tariff?
Thank you very much
Mycraft5 Dec 2016 17:48
It depends on whether your utility provider offers a heat pump tariff...
Alex85
5 Dec 2016 18:54
Horsti schrieb:
Do I now need an additional meter and a separate electricity tariff?
You only need one if the electricity provider’s terms and conditions exclude the use of heat pumps on the standard household electricity tariff. How they would find out is another question... You might consider installing a second meter if your supplier offers a special heat pump tariff that provides comparatively lower consumption costs. However, make sure to calculate carefully! Often the price per kWh is low, but the monthly fixed fees, which include the costs for the second meter, often offset the savings from the heat pump tariff, making the second meter uneconomical.
toxicmolotof
6 Dec 2016 14:19
Who is "your" utility provider? That’s the main factor that will determine everything, and you are initially free to choose your provider.
What electricity consumption are you expecting for the heat pump? If the savings from the cheaper heat pump electricity are offset by the extra costs of the electricity meter, then installing an additional meter doesn’t make sense.
All of this should ideally be discussed with you before the meter installation takes place.
