ᐅ After using furniture polish, the Kallax shelving unit became slippery – how should this be treated?
Created on: 18 Feb 2021 08:23
RongiHello everyone,
I recently treated my IKEA Kallax with furniture polish to care for the wood and give it a fresh look. However, I noticed afterward that the surface became significantly more slippery than before – both when placing decorations and when touching it, the shelf feels almost "slippery."
Now I’m wondering how to reduce this excessive slipperiness without damaging the wood or completely losing the protective effect. Are there any special products or home remedies that can dissolve or neutralize this slippery layer? Or do I need to remove the polish entirely and then reseal the wood?
I would really appreciate any tips and experiences regarding this issue, especially on how to best care for the shelf afterward to prevent it from becoming slippery again.
Hi Rongi,
"I’m wondering how to reduce this kind of excessive smoothness without damaging the wood or losing the protective effect entirely?" – that’s really a tricky issue. Furniture polish can sometimes be surprising, especially when it leaves a film that feels more slippery than protective.
I had a similar problem with my coffee table, and what helped was first cleaning the surface thoroughly with a soft cloth and some lukewarm water to remove excess polish. Then I let the furniture dry completely and gently sanded the top layer with a very fine sanding pad (one of those sanding sponges for wood) – but only lightly, so as not to completely remove the effect of the polish.
Maybe that could be an option for your Kallax as well?
Oh, and be careful with too aggressive cleaners, as they could damage the wood. This is especially counterproductive for furniture with a thin varnish layer. A little patience and careful testing never hurts.
Did you happen to use a water-based or oil-based polish?
Rongi schrieb:
Are there any special products or home remedies that can dissolve or neutralize this slippery layer?Home remedies are often old myths that only work in certain cases. Furniture polish is usually a chemical with a polymer film. If you really want to get rid of the layer, you probably need to either mechanically remove it (sanding) or use a solvent-based cleaner, which can definitely damage the surface.
Sometimes I wonder if all this "polish" stuff isn’t more of a marketing fiction – it’s supposed to protect the furniture but often causes unnecessary problems. Why not just use wax if you want something low-maintenance?
Of course, you could also switch completely to natural oils that absorb into the surface and don’t leave it slippery.
Just some food for thought…
Layla schrieb:
I once had a similar issue with my coffee table, and it helped to first clean the surface thoroughly with a soft cloth and some lukewarm waterI completely agree 😊. With such a slippery finish, it can sometimes feel like you’re on ice.
What helps is to start by gently cleaning, not scrubbing, and then very lightly sanding with fine sandpaper or a sanding sponge. Like Layla said – just enough to remove the haze. After that, you should polish the surface with a dry cotton cloth to make the material nicely matte and less slippery.
And honestly – Kallax is quite sturdy, so you can safely experiment a bit without worrying about damage. Good luck! 😎
LIELCHEN schrieb:
Home remedies are often outdated myths that only work in specific cases.I agree with that. I once had the problem that furniture polish made the wood very slippery, and simple home remedies barely improved the finish visibly.
What worked best for me was carefully removing the polish with an alcohol-based cleaner and then lightly sanding the surface. However, it’s important to reseal the wood afterward to prevent unnecessary damage.
It’s essential to proceed gently and test the treatment on an inconspicuous area first.
I hope you find something that works well for you!
