ᐅ After changing the wall color, the KALLAX unit appears yellowish – do I need new doors?
Created on: 14 Mar 2024 09:17
V
VINON
I recently repainted the wall in my living room and chose a color that is warmer and more yellowish than before. Right after that, I noticed that my IKEA KALLAX shelf, which used to look white, now appears quite yellowish – this color shift effect is quite disturbing. My question is whether, in such a case, the paint color only changes the perception and one can get used to it, or if the yellowish "staining" is strong enough that it would actually make sense to replace the doors of the KALLAX shelf?
Are there maybe other tips on how to neutralize the yellowish appearance without having to buy new furniture accessories right away? I look forward to your assessments and experiences!
likuken
14 Mar 2024 17:47
blapau schrieb:
Universally light-colored furniture appears particularly vulnerable because it absorbs and reflects light more strongly.
That’s a valid point – but honestly, I often find the whole fear of slight color variations somewhat exaggerated. A yellowish tint isn’t inherently bad; it can actually add character to a room.
Why not simply choose doors in a warm tone and make that a design feature? I think white doors can quickly feel dull and sterile.
The whole idea of “neutral colors” is often a self-imposed limitation. Who says KALLAX has to stay cold? Maybe a chalky vanilla shade actually enhances the look?
At least I wouldn’t rush to buy new doors right away, but rather play around and experiment, instead of treating the color shift as a problem.
KLO-KA
14 Mar 2024 18:31
New doors can help, but not necessarily. If the yellowish tint comes from the ambient lighting, better room illumination might also alleviate the problem.
Sometimes small adjustments, such as an additional bright light source or a different lamp holder, are sufficient. Replacing doors is then a more demanding solution.
Nathanaelk
15 Mar 2024 08:59
Although much has already been discussed, I would like to add a few technical details that could help you make an informed decision.
First of all, it is important to understand that your KALLAX shelf is probably coated with a white melamine finish. This reflects ambient light, which causes color changes on the wall to visually affect the appearance of the furniture—though this is purely optical, not physical.
If the wall color has a yellowish tint, the light scatters with warm wavelengths that are reflected by the glossy surface of the KALLAX. People then perceive this as a yellowish hue.
There are technical solutions, such as modifying the surface coating by applying a film or painting it with a cold white, matte color, which reduces these reflections.
Regarding the light source: light sources with a high CRI (around 90 or above) should be preferred, as they reproduce the color spectrum most naturally.
It would also be helpful to check the lighting design—point spotlights on the ceiling or diffuse wall washers avoid harsh shadows and color casts. If you like, I can prepare a brief guide on proper lighting planning and color coordination. What is the general room lighting like at the moment?
BARSAN
15 Mar 2024 10:11
I would recommend testing with sample doors first before buying new ones.
Sometimes, even a slightly cooler white or a subtle gray undertone can significantly reduce the yellowish tint.
If the shelf only appears yellowish but is not permanently discolored, a complete replacement is usually not necessary.
