ᐅ After renovating the apartment, the Kallax unit has surface damage – any repair tips?
Created on: 18 Nov 2024 08:37
BikubuHello everyone, I’m currently facing a problem after my recent apartment renovation and would appreciate your advice. I have a Kallax shelf from Ikea that was in great condition before the renovation. Unfortunately, I noticed that paint or solvents from the painted walls seem to have affected the surface of the Kallax, resulting in ugly surface damage or stains. The affected areas also feel a bit rough, which I hadn’t experienced before. Does anyone have experience with this type of surface damage on MDF furniture or specifically with Kallax? I’d prefer not to replace the entire shelf and am wondering if there are practical repair tips – are there ways to smooth the surface again or at least improve its appearance? Any recommendations for tools, care products, or materials suitable for this would be greatly appreciated. Thanks in advance for your feedback!
Hello Bikubu,
first of all, it would be helpful to examine more closely what type of substance caused the surface damage. Kallax furniture is mostly made of particleboard with a melamine resin or foil coating, which is quite sensitive to solvents.
These stains could have been caused by swelling of the particleboard beneath the coating or the dissolving of the foil. For minor damage, I recommend the following approach:
1. Surface cleaning: First, use a mild detergent like dish soap to remove all residues.
2. Light sanding: Gently sand the affected area with fine sandpaper (grit 320 to 400) to smooth any uneven spots. Be careful not to remove too much material, as this could damage the edges.
3. Then treat the area with a melamine lacquer or a suitable furniture touch-up pen (often available at IKEA or hardware stores) to refresh the surface. Please test on an inconspicuous spot first!
4. If the surface is swollen or severely damaged, it may be necessary to use a special adhesive to fix small cracks or bubbles.
As an important question: How large are the damaged areas exactly, and are they mostly superficial or deep? It would also be useful to know whether the shelf was located indoors or outdoors, since moisture could also play a role.
If needed, I can gladly provide information on alternative materials or further repair methods!
Bikubu schrieb:
apparently paint or solvent from the painted walls has reached the surface of the Kallax and now ugly surface damage or stains are visible
Hello Bikubu,
I would like to provide a more structured guide on how to best address the damage on the Kallax. The typical Kallax shelves are made of particleboard with a melamine foil surface.
Common issues:
- Solvents can be aggressive and dissolve or discolor the foil.
- Rough spots occur when the foil has swollen or been damaged.
Repair procedure:
1. Cleaning: First, clean the affected area with warm water and a little dish soap. Then dry it with a lint-free cloth.
2. Sanding: Use very fine sandpaper (grit 600 or higher) to gently sand the rough spots. Avoid sanding too hard or generating heat to prevent further damage to the foil.
3. Scalpel trick: If the foil is lifting or bubbling, carefully remove any excess or loose foil with a sharp scalpel or cutter knife.
4. Repair with acrylic or furniture touch-up pen: There are special repair pens for laminate/melamine surfaces that you can color-match. Use these to fix small scratches and discolorations.
5. Sealing: Afterwards, I recommend applying a thin layer of clear furniture wax or a specially designed care product to protect the surface and enhance the gloss.
The most important thing is to proceed step by step and very carefully, as melamine foil can be further damaged if treated improperly.
That’s a good point, but only use this method if really needed—otherwise, treat the surface gently.
If you have any further detailed questions, I’m happy to help!
Common issues:
Repair procedure:
Palenar schrieb:
If the surface is swollen or severely damaged, it may be necessary to fix small cracks or bubbles with a special adhesive
Hey Bikubu, that’s really frustrating with the Kallax after the renovation! 😊
I had a similar issue once and here’s what I did: I first used a mixture of water and isopropanol to clean and remove all solvent residues. That already reduced the stains quite a bit.
Afterwards, I used special furniture markers – they come in different colors and are great for covering up small scratches. The shelf almost looked like new again! So don’t get discouraged; this kind of damage can actually be fixed quite well.
Also, I would recommend treating the surface afterwards with a suitable furniture wax to protect it nicely. Good luck! 🙂
