ᐅ After moving in, the corners of the Kallax units are denting from impacts – how can this be concealed?
Created on: 22 Apr 2020 20:13
nitano
nitano
22 Apr 2020 20:13
I recently moved into my new apartment and have already assembled a Kallax shelf from Ikea. Unfortunately, I noticed that the corners of the shelf—especially at the edges that often get bumped by furniture or doors—start to break apart and peel off quite badly after only a short time of use. The MDF panels are quite fragile, and despite careful handling, visible damage has already occurred.
Does anyone have tips or proven methods for disguising these Kallax corners without having to replace the entire shelf? It should remain as inconspicuous as possible, for example through repair, covering, or simple DIY solutions. I’m also interested in ideas on how to prevent such damage in the future.
I look forward to your experiences and suggestions!
WARREN
22 Apr 2020 21:42
Hi,
use acrylic or wood filler to fill in the damaged areas. Afterwards, you can touch up with a suitable paint or marker. For the corners, self-adhesive plastic corner protectors are also helpful.
This hides the damage well and protects against further wear.
nanidra
23 Apr 2020 00:08
nitano schrieb:
The MDF boards are quite delicate, and despite careful handling, visible damage has already occurred.
That’s the dilemma with Kallax — many people buy it because it’s affordable and has a modern look, but the durability is questionable. Why not just get a genuinely sturdy shelf? However, if you have to accept the limitations, the only option is to creatively conceal the damage.
For example, I would personalize the corners with colored nail polish or small vinyl stickers, so at least you have a design feature instead of an unattractive flaw.
The magic word is “design instead of repair.” :-)
raquel52
23 Apr 2020 10:37
From a technical perspective, it makes sense to smooth the edges mechanically first, carefully removing any frayed parts with sandpaper. Then, the damaged corner can be filled with wood filler, ideally matched to MDF to prevent stress.
Afterwards, sealing with a color-matched acrylic paint is recommended. For a less noticeable finish, a small paint roller can be used to apply the paint evenly.
Alternatively, self-adhesive edge protectors made of plastic or aluminum are suitable and provide extra protection against frequent wear.
To prevent damage, using sturdy spacers or repositioning the furniture is advisable to avoid direct impacts on the Kallax corners.
Lisele
23 Apr 2020 14:55
nanidra schrieb:
Why not just use a really sturdy shelf right away?
I can understand that, but often such furniture choices come down to budget or space constraints. I’m familiar with the disappointment of damaged corners – it quickly feels like you haven’t been careful enough with your own home.
To cover them up, I’ve had good results with small wooden strips that you can glue onto the affected corners. This also provides protection for the future and looks really nice in light colors.
Especially if, like me, you want something a bit stylish, it can even create a nice look. 🙂 The important thing is not to get frustrated and to see the solution as a kind of “upcycling.”
Deandre
24 Apr 2020 09:12
Hello nitano,
You have already described well that MDF corners tend to crack from impacts, which unfortunately is not uncommon for this type of material. Here is a step-by-step recommendation to help you repair and protect the corners yourself:
1. Preparation: Clean the damaged areas and carefully remove any loose wood fibers to create a smooth base.
2. Filling: Use a filler suitable for wood or MDF to fill in the missing or damaged corners. Let it dry thoroughly, then sand it smooth.
3. Painting: Choose an acrylic or furniture paint in a color that matches the shelf well (usually white or light gray). Apply the paint thinly so that the repair is hardly noticeable.
4. Protection: To minimize future damage, you can install corner protectors made of plastic or metal. These can be simply glued or screwed on.
5. Alternative: For a quick and decorative solution, self-adhesive films or stickers can be applied to cover the damaged corners.
If you like, I can also provide tips on product selection. 🙂 Let me know if you have any questions about the individual steps!
