ᐅ After installing caster wheels, my Kallax unit has become unstable – have you experienced the same?
Created on: 8 Dec 2023 09:17
deoteoHello everyone,
I recently installed caster sets on my IKEA Kallax shelving unit to make it easier to move around. However, after fitting them, I noticed that the unit feels considerably less stable – it wobbles noticeably, especially when it’s lightly bumped or when you lean on it. I have already checked that all screws are tight and the casters are properly installed, but the problem persists.
I’m curious if any of you have experience with this: does fitting casters generally affect the stability of the Kallax, or could this be due to an installation error? I want to avoid the shelf tipping over or getting damaged.
Thanks in advance!
Thanks in advance!
deoteo schrieb:
After installation, I noticed that the shelf now seems quite unstable overall – it wobbles significantly more, especially when it is lightly bumped or when you lean on it.Unfortunately, this is a common issue when adding casters to a Kallax unit. The stability decreases mainly because casters are designed to absorb floor unevenness and are not as rigid as a fixed base.
It is important to check whether your casters have a locking function that limits movement. Ideally, mount the casters exactly centered under each side panel to distribute the weight evenly.
You might also consider attaching a wall bracket at the back if the shelf is placed close to a wall; this greatly improves overall stability.
Typically, IKEA casters are not designed to support heavy loads stably—so if your Kallax is fully loaded, this makes the wobbling worse.
How did you mount the casters? Screws at the bottom edge or is there a better attachment method? Have you checked if the floor at the contact points is truly level?
Hello deoteo,
I understand your concerns about the instability. The Kallax was not originally designed to be used with casters, so the entire construction can indeed behave more "nervously" on wheels compared to a fixed base.
A while ago, I also installed casters and initially the shelf wobbled quite a bit.
Important points:
- Check if the casters are evenly and properly screwed in.
- Measure if they are all the same height. Different heights cause wobbling.
- One option is to reinforce the casters by attaching them to an additional plate.
- Also, remember to ideally secure the shelf against tipping, for example, with a wall mount or anti-tip devices.
If you want, I can gladly explain in detail how I implemented this myself.
Important points:
deoteo schrieb:
After installation, I noticed that the shelf now feels quite unstable overall – it wobbles much more, especially when it is lightly bumped or when leaning on it.Hi,
here is a structured overview that might help you identify the cause and implement possible solutions:
1. Installation check:
- Are all the casters mounted exactly as specified and at the same positions?
- Are all screws tightened properly, and are the casters correctly threaded into the fittings?
2. Floor condition:
- Is the floor truly level? Even minor unevenness can cause wobbling because casters transmit vibrations.
- A shelf on casters absorbs floor irregularities more noticeably than a stationary piece of furniture.
3. Load distribution:
- Are you loading the unit mostly at the bottom or unevenly?
- An unevenly loaded shelf tends to wobble more.
4. Caster quality:
- IKEA casters are designed for light loads, so if you plan to store heavy items, you might need higher-quality casters.
5. Stabilization:
- Wall mounts or additional bracing
- Placing a board or panel underneath to distribute the load area can help.
In summary: Remove the casters, check everything again, consider casters with locking mechanisms, and adjust the caster height if possible.
Summary:
Casters always add mobility but also increase instability, so targeted stabilization measures are necessary.
I hope this helps!
