ᐅ After contact with rubbing alcohol, streaks have appeared on the Kallax surfaces – how can they be removed?
Created on: 4 Dec 2020 19:37
befega
befega
4 Dec 2020 19:37
I accidentally used rubbing alcohol on my Kallax shelves with white melamine coating. Unfortunately, this caused unsightly streaks on the surface, which partly appear slightly dull and significantly reduce the shine. The marks are neither greasy nor sticky but look as if the protective layer has been partially damaged or dissolved.
Does anyone have experience with removing these streaks without damaging the surface? I would prefer to avoid using stronger agents that might cause further damage.
What’s important to me:
- no solution that harms or dulls the melamine surface
- preferably common household products
- a lasting effect, not just a temporary "cover-up" of the marks
I look forward to your tips – thanks in advance!
Hannes
4 Dec 2020 19:48
Simply try gently wiping the spots with a damp cloth and some dish soap. If that is not enough, apply a small amount of furniture polish or car polish and buff the area. Use sparingly to avoid any stickiness.
LENNAU
5 Dec 2020 08:26
befega schrieb:
I accidentally used rubbing alcohol on the white melamine-coated surfaces of my Kallax shelves. Unfortunately, this caused unsightly streaks on the surface, some of which appear slightly dull and reduce the gloss.
Hello befega,
These streaks often occur when the melamine coating is superficially dissolved by the alcohol. It is important in such cases not to continue treating the surface with alcohol or strong solvents, as this can permanently damage the protective layer.
Recommended steps:
1. Gently clean the surface with a microfiber cloth and lukewarm water.
2. Then apply a fine furniture polish or maintenance wax specifically designed for laminate/melamine to restore the gloss and protective layer.
3. Apply evenly and gently buff in.
If the dullness remains, you can try using a very fine polishing cloth and carefully polish the area. Proceed cautiously to avoid further damaging the surface.
Please test the polish on an inconspicuous spot before treating the entire surface.
If you have any further questions about the process, I’m happy to help!
Linavin
5 Dec 2020 09:41
LENNAU schrieb:
Procedure: 1. Gently clean with a microfiber cloth and lukewarm water. 2. Then apply a fine furniture polish or care wax specifically designed for laminate/melamine.
This approach sounds reasonable, but I would question whether a polish can really “repair” all damage caused by cleaning alcohol if the surface has already been dissolved.
Therefore, I recommend considering the reverse: Does anyone have experience with the resistance of Kallax melamine coating to cleaning alcohol? Are the streaks merely superficial residues, or are they actually irreversible changes in the material?
If irreversible, replacement or repainting is probably the only option – which is quite labor-intensive for a Kallax shelf. There is also a high risk of color or gloss differences in that case.
Does anyone know of independent sources or manufacturer guidance on such cases?
Fitigu
6 Dec 2020 10:02
Linavin schrieb:
If irreversible, replacement or repainting is probably the only option – which is quite a hassle for a Kallax shelf.
For clarification: The Kallax melamine surfaces consist of a thin melamine resin layer on engineered wood. This protective layer is relatively resistant to water and most everyday cleaners, but aggressive solvents like rubbing alcohol can cause microscopic damage that appears as dull streaks.
My recommendation:
- Avoid further use of alcohol.
- Always clean with a mild detergent and a soft cloth.
- For treating the streaks, use a special plastic or laminate cleaner.
- If necessary, you can apply a specialized surface polish for melamine that fills micro-scratches with a very thin layer and restores the gloss.
Please do not use abrasive cleaners! The damage is usually superficial and can be corrected; deeper damage is rare and unfortunately permanent.
This should help, good luck!
