ᐅ After 2 years with KALLAX – would you buy it again?
Created on: 15 Feb 2024 09:23
Peofredrik
About two years ago, I bought the KALLAX shelving system from IKEA and have been using it in my living room as a combination of a bookshelf and storage for smaller items. Since I am now considering purchasing another KALLAX, I am especially interested in its long-term everyday practicality.
My question to you: After around two years of use, would you buy the KALLAX shelf again? What has been your experience regarding stability, material quality, and flexibility for different uses? Are there things you would have done differently in hindsight, or alternatives you would recommend?
I look forward to your feedback and opinions!
Peofredrik
16 Feb 2024 08:44
koduga schrieb:
I want to encourage you to describe your specific requirements in more detail.
Good point. Specifically, I primarily need the KALLAX for books and lever arch files. The load is moderate, but sometimes the lack of flexibility in shelf height is frustrating because files are taller than books. That’s why I’m interested in expanding it with additional shelves or considering other construction methods. Stability is important to me because the unit is placed against a frequently used wall where things are occasionally set down.
Thanks for the encouragement—I hope this helps you with your assessment.
KIN42
16 Feb 2024 10:11
Peofredrik schrieb:
sometimes the lack of flexibility in the height of the compartments is annoying
That’s true, KALLAX compartments have a fixed height of about 33 cm (13 inches), which limits storage space.
A practical solution is to expand individual compartments with custom wooden shelves or inserts tailored to your needs. Alternatively, you can consider IKEA’s Besta system, which offers more options for adjusting compartment heights.
te-min
16 Feb 2024 11:27
I bought KALLAX two years ago for an office and would definitely buy it again. It is very low-maintenance and sturdy.
Regarding standard sizes: If you plan to store binders frequently, it’s worth considering either an additional shelf or combining it with KALLAX inserts with doors.
The price is also unbeatable for what you get.
SONLIS
16 Feb 2024 14:55
All previous posts have been helpful. I would just like to add that for long-term use of KALLAX, it is important not to neglect regularly tightening the screws. Due to the materials and assembly method, connections tend to loosen slightly over time, which is not critical but noticeable.
Additionally, I recommend considering the use of optional glides or felt pads under the furniture to protect the floor and prevent slipping. This increases safety and durability.
Finally, it should be noted that specially designed shelving systems are generally better suited for very heavy loads, but KALLAX is appropriately sized for normal household use.
DUVIN
17 Feb 2024 09:14
As
KINMIN4 schrieb:
Stability is excellent, it delivers everything it promises
already mentioned, the KALLAX is more affordable compared to similar products but still offers a solid basic stability.
However, after two years, I experienced minor issues with some connection points, which loosened slightly due to the typical swelling of chipboard when exposed to moisture.
In general, I would recommend not placing the KALLAX directly in damp or highly fluctuating environments.
Regarding repurchase: Yes, considering its price-performance ratio, the KALLAX is highly recommended, especially if you value a simple design and want to avoid investing too much in custom modifications.
