ᐅ Aerated concrete exterior plaster/render
Created on: 24 May 2014 17:09
bygoran
bygoran
24 May 2014 17:09
Hello
I would be interested in some advice regarding exterior plaster for aerated concrete.
What would you recommend? Which materials and what application order?
The plasterer is asking me more than three times the price per square meter compared to interior plastering. Could that be correct?
I prefer a fairly smooth finish. I'm not really a fan of rough plasters.
I hope you have some tips for me or some recommendations on which materials to use.
Irgendwoabaier
24 May 2014 19:12
That makes sense – on the inside, you don’t have to worry about wind-driven rain resistance and similar issues, so the material requirements on the exterior are somewhat different. Otherwise: use a sealed system where all components are coordinated, and have a professional with experience in these materials handle it. DIY usually isn’t cost-effective here.
I.
bygoran
25 May 2014 11:13
It’s about the labor, not the material.
If the material is more expensive, that wouldn’t be a problem, but I don’t think it’s fair to pay more than three times the labor cost for the same work.
He wants to first prime the house, then apply a cement render, and afterwards install the facade. At least that’s how I understood it.
Online, I read that aerated concrete can be rendered more easily or in a different way.
Irgendwoabaier
25 May 2014 12:14
The work is also somewhat different... Base plaster, reinforcement, finish plaster, and depending on the system, applied in several layers – it’s definitely not the same kind of work.
By the way, on the websites of a major aerated concrete manufacturer, you can find plastering recommendations (just try searching on Google) – this can help you estimate the amount of work involved.
emer25 May 2014 13:56
A scaffold will probably need to be erected outside. Inside, this was most likely not the case.
