ᐅ Additional Costs Due to Incorrectly Designed Ventilation System and Floor-to-Ceiling Windows?
Created on: 29 Nov 2016 01:14
3
305er
Hi, we have our final planning meeting on December 13th, after which everything will be sent to the building authority (building permit / planning permission).
From the beginning, I told my salesperson that the outdoor unit of the Rotex ventilation system was incorrectly positioned in the first offer. The layout shown is not possible because the garage is supposed to be there.
I was told, "No problem. This can be changed in the planning phase and moved up."
Now I wrote to the CEO to have this corrected.
The reply was only:
On your floor plan, you moved the outdoor unit of the heat pump to a different location. This is not possible with the contractual Rotex heat pump. A Novelan LAD heat pump is required, and the outdoor unit must be moved further to the right, against the outer wall of the study room.
Here are the costs: Change to Novelan LAD + 2,138.00 €
Extension of the outdoor unit + 1,509.00 €
The reason is that the outdoor and indoor units have to be aligned at the same height/line.
Of course, I disagree with this.
Do you have any suggestions on how to solve this without extra costs or significant loss of space?
The pantry shown in the picture will be removed, and the utility room (HAR) will be made larger instead.
Point 2:
I wanted to replace the two large floor-to-ceiling terrace windows in the kitchen with one standard window, because the kitchen island will be placed against that wall.
Reply:
– Changing the floor-to-ceiling windows in the kitchen to standard windows with a masonry sill is possible at the same price in the project planning.
Question: By “standard” you mean? So two large floor-to-ceiling windows cost the same as one normal window?
Point 3:
Colored front door with a small side panel, ADDITIONAL COST 1,464€???? That seems quite high for just a bit of paint or finish, right?
Point 4:
I want to install a horizontal window at the top of the hallway to bring light into the room (we don’t want double casement windows). We saw this in a prefab house with the same knee wall height as ours.
Reply:
In the current plan, the window is not possible because the wall height is insufficient. Otherwise, the window would have to be fixed and equipped with TRAV glazing. The cost would be around 1,400.00 € to 1,600.00 €.
What do you think?
Point 5:
Price reduction for removing the standard front door: -1,315.00 €
But if I want an additional door, it costs me over 4,000 €. How is that possible?
See the attached picture.
Maybe they want to remove it because the door is not good enough — no RC2 rating, no windows with privacy glass, etc.
Here is the description:
Your contract includes a white plastic front door from the standard range with a small side panel.
The side panel has clear glass; satin glass can of course be added separately.
The front door has basic security, which should correspond approximately to WK 1, but a higher standard is possible and can be arranged.
According to the contract, a handle about 30 cm (12 inches) long is agreed.
Point 6:
Are the floor-to-ceiling windows on the upper floor acceptable? Or do they let in too little light?
Would a standard window be better? What is considered standard? What size is that?
So, that’s it for now. I actually wanted to write very little, just one or two points.
Thanks
Ground floor plan: living/dining room, kitchen, study, hallway, WC, utility room (HAR), pantry (SPK), staircase.
Attic floor plan with 3 bedrooms, dressing room, bathroom, hallway, and storage room.
Alex85
4 Dec 2016 11:11
Getting a very hot full bath and two showers from 180 liters (48 gallons) is a good indication that these storage sizes should definitely not be considered too small. Based on your shared experience, I rather wonder what to do with, for example, 300 liters (79 gallons) of external storage – in reverse, those would probably never even come close to being empty and are therefore likely uneconomical.
Bauexperte
4 Dec 2016 11:15
Alex85 schrieb:
Based on your shared experience, I wonder what you would do with, for example, 300 liters (79 gallons) of external storage...
It is not necessary, but the typical homeowner "feels" more comfortable with a larger tank. In other words, bigger means longer baths and showers.
This is definitely good news for the manufacturers.
Evolith
4 Dec 2016 14:18
We are also getting 300 liters (79 gallons). For my peace of mind, 250 liters (66 gallons) would have been more than enough. But well, the offers are what they are.
Payday
4 Dec 2016 15:05
Bauexperte schrieb:
They are not necessary, but the average homeowner “feels” better with a larger tank. Basically, bigger means longer baths and showers.
This is of course good news for the manufacturer
and the energy supplier, since storing hot water always wastes energy—even with good insulation. Every extra liter of water in the storage tank is money thrown away. Rare peak situations that occur once a year or less don’t necessarily need to be covered. If 180 liters (47 gallons) is enough for one bath plus one or two showers, a larger volume only makes sense for large families or people with a hot tub or similar.
In those cases, it’s more practical to install a hot water recirculation pump, so the hot water comes out immediately rather than after 20 seconds or so.
Bieber0815
4 Dec 2016 23:22
305er schrieb:
180L water tank? Isn't that way too small?
As Alex85 indicated, it also depends on the storage temperature. And of course on the usage pattern. If you know these basic details and also the heating system’s output (for recharging), you can calculate the required storage volume.
lin0r873 Dec 2019 12:58
is a Novelan LAD 5 DUAL CSD recommended?
Or should we opt for a Viessmann VOTOCAL 200-S?
