ᐅ Additional Costs Due to Incorrectly Designed Ventilation System and Floor-to-Ceiling Windows?
Created on: 29 Nov 2016 01:14
3
305er
Hi, we have our final planning meeting on December 13th, after which everything will be sent to the building authority (building permit / planning permission).
From the beginning, I told my salesperson that the outdoor unit of the Rotex ventilation system was incorrectly positioned in the first offer. The layout shown is not possible because the garage is supposed to be there.
I was told, "No problem. This can be changed in the planning phase and moved up."
Now I wrote to the CEO to have this corrected.
The reply was only:
On your floor plan, you moved the outdoor unit of the heat pump to a different location. This is not possible with the contractual Rotex heat pump. A Novelan LAD heat pump is required, and the outdoor unit must be moved further to the right, against the outer wall of the study room.
Here are the costs: Change to Novelan LAD + 2,138.00 €
Extension of the outdoor unit + 1,509.00 €
The reason is that the outdoor and indoor units have to be aligned at the same height/line.
Of course, I disagree with this.
Do you have any suggestions on how to solve this without extra costs or significant loss of space?
The pantry shown in the picture will be removed, and the utility room (HAR) will be made larger instead.
Point 2:
I wanted to replace the two large floor-to-ceiling terrace windows in the kitchen with one standard window, because the kitchen island will be placed against that wall.
Reply:
– Changing the floor-to-ceiling windows in the kitchen to standard windows with a masonry sill is possible at the same price in the project planning.
Question: By “standard” you mean? So two large floor-to-ceiling windows cost the same as one normal window?
Point 3:
Colored front door with a small side panel, ADDITIONAL COST 1,464€???? That seems quite high for just a bit of paint or finish, right?
Point 4:
I want to install a horizontal window at the top of the hallway to bring light into the room (we don’t want double casement windows). We saw this in a prefab house with the same knee wall height as ours.
Reply:
In the current plan, the window is not possible because the wall height is insufficient. Otherwise, the window would have to be fixed and equipped with TRAV glazing. The cost would be around 1,400.00 € to 1,600.00 €.
What do you think?
Point 5:
Price reduction for removing the standard front door: -1,315.00 €
But if I want an additional door, it costs me over 4,000 €. How is that possible?
See the attached picture.
Maybe they want to remove it because the door is not good enough — no RC2 rating, no windows with privacy glass, etc.
Here is the description:
Your contract includes a white plastic front door from the standard range with a small side panel.
The side panel has clear glass; satin glass can of course be added separately.
The front door has basic security, which should correspond approximately to WK 1, but a higher standard is possible and can be arranged.
According to the contract, a handle about 30 cm (12 inches) long is agreed.
Point 6:
Are the floor-to-ceiling windows on the upper floor acceptable? Or do they let in too little light?
Would a standard window be better? What is considered standard? What size is that?
So, that’s it for now. I actually wanted to write very little, just one or two points.
Thanks
The reply was only:
Point 2:
Reply:
Point 3:
Point 4:
Reply:
What do you think?
Point 5:
Point 6:
Thanks
Hello Sven,
For an exterior door, it is very important that the hinges, seals, strike plates, and so on are of very high quality, since the door will be used frequently. Who is going to install the door? Which brand of aluminum doors does your general contractor offer? There is a rather large door showroom south of Darmstadt (you can look it up), where you could take a look and get some information.
Sabine
Sabine
I would also suggest visiting several door showrooms to get customized quotes based on your specific requirements. If you buy a front door "off the shelf," you might face the problem that it doesn’t fit exactly, and you will also need to find someone to install it for a fee.
Michael
Michael
The original idea was actually that the house construction company would install it.
And what do you mean by "doesn't fit"? If I provide the measurements, they have to make the opening accordingly, right?
We also visited our local spring fair once, where there were several door sellers. But they can tell you anything they want when you don’t know what to look for when inspecting and handling the products yourself. Of course, everyone says their door is better because...
Well, it might be that they charge more for the opening you need because:
1. The structural calculations are different
2. A larger lintel is required
3. Additional masonry work may be necessary
4. Small components are needed
and so on.
So, the potential savings are rather limited... if it’s "just" about the door.
and so on.
305er schrieb:
The original plan was for the home builder to install it.
What do you mean by "doesn't fit"? If I provide the measurements, they should make the opening to fit, right?
...It won’t be the home builder, but the window and door specialist who will install it.
What’s stopping you from asking them directly what other services they offer? If you buy from them, you can be sure they will also handle the door installation.
And what’s stopping you from asking him directly about what else he offers? If you buy from him, you can be sure that he will also install the door. This is how we handled our staircase. We removed the trade from the contract due to our custom requests but still hired the general contractor’s standard stair builder. That way, everything fit together just like usual, but we still saved money.
