ᐅ Access / Inspection Attic
Created on: 30 Mar 2017 15:36
bluminger
bluminger30 Mar 2017 15:36
Hello.
In our case, the attic/roof cavity will not be accessible, so there will be no retractable ladder (to avoid compromising insulation and prevent moisture ingress). Most of the roof insulation is also installed at the level of the intermediate collar beams.
What are some reliable solutions for still providing occasional access for maintenance, for example, an entry that might be needed only every 10 years (or never)?
An externally operable gable window? Other ideas?
Thank you in advance for your suggestions on how to handle this.
11ant30 Mar 2017 16:05
Every cavity is also a potential breeding ground. Even filtered air carries particles inside. I consider this idea unrealistic. Where does the chimney sweep get off?
Nordlys
30 Mar 2017 16:15
I agree. Karsten
