F
foxmulder4 Nov 2017 22:12Hello everyone,
We have a 4m (13 feet) wall recess in our bedroom and would like to install a built-in wardrobe. Is it possible to fit a 4m (13 feet) wide Pax wardrobe into this recess? The baseboards would, of course, be removed.
If the niche measures 400 cm (13 feet) after construction, it should just fit. You will need to adjust it slightly. My niche was 200 cm (6.5 feet) and I was able to fit a 200 cm (6.5 feet) Pax unit in there.
However, if the rough opening is 400 cm (13 feet), I would recommend arranging for the rough opening to be planned at 405 cm (13.3 feet).
Ghostwriter4 Nov 2017 22:20foxmulder schrieb:
we have a 4m (13 feet) wall recess in our bedroom and would like to install a type of built-in wardrobe. Is it possible to fit a 4m (13 feet) wide PAX wardrobe into this niche? Baseboards would of course be removed.Check whether you have the full 4m (13 feet) height as well.In our rental apartment, we had a 3.5m (11.5 feet) niche. Unfortunately, only at floor level, because the plaster bulged in the middle. In the end, we had to shorten the wardrobe by nearly 2cm (0.8 inches). But it still worked.
F
foxmulder4 Nov 2017 22:43Thank you very much for the quick responses
