ᐅ 4-pole momentary push button with center position compatible with Busch-Jäger systems
Created on: 7 Jan 2011 08:45
MaddinHello dear forum community,
First of all, Happy New Year 2011!!! And I already have a question or rather a request:
Hager offers "group push buttons with a neutral middle position," which are 4-pole, designed to control (up/down) two different consumers, and are labeled WUE34. Unfortunately, no covers from the Busch-Jäger switch program fit on these, and Busch-Jäger does not offer anything comparable... ;-(
Throughout the entire house, Busch-Jäger Duro 2000 has been installed, so using covers from the Hager program is unfortunately not an option.
Does anyone here in the forum know of another manufacturer that produces 4-pole series push buttons with a neutral middle position, ideally compatible with Busch-Jäger Duro 2000?
Another solution would be if suitable rocker switches with outer dimensions of 50x50mm (2x2 inches) were available, then the spacer ring (central telecommunications disc 1746-212-101) could be integrated into the Busch-Jäger covers.
The push buttons are to be connected with YJ(ST)Y 2x2x0.6 cable to an Elsner conservatory control system (24V low voltage, locking is done within the device).
Thank you very much for any helpful tips and have a nice day.
There are also 4-pole push buttons with a neutral middle position from Gira. However, the covers and toggle switches of Gira’s cream-white models don’t really resemble those of Busch-Jäger.
Does anyone else in the forum know of other manufacturers offering 4-pole push buttons with a neutral middle position, ideally compatible with Busch-Jäger Duro 2000?
Hello Maddin,
here is some information about the B&J switch system
Busch-Jaeger - Blind control module 6411U-101
Here are all the details for the switch/button:
Busch Blind Control II Module
Type: Flush-mounted
Suitable for roller shutters, blinds, and awning drives with mechanical or electronic limit switches.
Includes two 230 V auxiliary inputs (up/down) for group control.
Operating mode switch with modes: Normal, Slat, Central, Position.
Party function (disables local control) when used with Busch Blind Control II user interfaces 6430-xx-xxx, 6066-xx-xxx.
Wind alarm and cleaning function can be activated via auxiliary inputs.
Compatible with user interface 6430-xx-xxx, IR user interface 6066-xx-xxx, and comfort timer interface 6455.
Running time: 3 minutes
Rated voltage: 230 V~, +10% / -10%
Rated frequency: 50 Hz / 60 Hz
Outputs: 2 normally closed contacts
Rated current: 3 A, at cos φ 0.5
Rated power: 690 VA
Control / signal outputs: 2
Operating temperature range: 0°C to 35°C (32°F to 95°F)
Hopefully, I won’t get another warning because of this.
This one should actually work.
Type: Flush-mounted
Rated power: 690 VA
