ᐅ 3x1.5 mm² or 5x1.5 mm² NYM cable in the roof cavity for LED spotlights?
Created on: 25 Jan 2019 21:26
hauspeter
I want to run an electrical cable all around the roof box to operate LED spotlights.
What are the advantages and disadvantages of using 3-core or 5-core cables for lighting?
Mycraft4 Feb 2019 14:52
GU10 sockets are usually supplied with cables.
O
Obstlerbaum
4 Feb 2019 15:04
Seriously? You’re hanging your lights on bare sockets?
Mycraft4 Feb 2019 15:23
Yes, really,
even when the base is installed in a housing or inside a lamp, it looks no different inside. GU10 comes with a cable.
hauspeter
4 Feb 2019 16:56
Obstlerbaum schrieb:
Do I understand this correctly: NYM cable -> terminal block -> extension cable -> terminal block -> GU10 socket? So if there is enough cable length, why do it this way?
The rigid NYM cable was run up to the roof overhang and then extended with a flexible two-core cable. It looked like speaker cable with a corresponding cross-section. This cable was easier to bend and connect to the GU10 sockets.
O
Obstlerbaum
4 Feb 2019 20:38
Mycraft schrieb:
Yes, really,
even if the socket is installed inside a housing or a lamp, it doesn’t look any different inside. GU10 comes with a cable.
The end customer doesn’t need to worry about the internal construction. Cable in the terminal, done.
Mycraft5 Feb 2019 09:19
Doesn’t matter either way. Still, they are almost always just bare sockets with wires attached.
