Does anyone have a tip on the best way to insulate my top floor ceiling (new build)?
There will be 260mm (10 inches) high collar beams installed, but according to the calculation, I need to install 280mm 035 insulation.
Ideas so far (please provide feedback/criticism):
- Adding boards along the beams and installing 180mm + 100mm insulation
- Adding boards along the beams and installing 280mm insulation (280mm insulation is expensive)
- Adding layers across the beams: 160mm + 100mm between the beams and 20mm across the beams (24mm battens)
- Adding layers across the beams: 260mm (more expensive) between the beams and 20mm across the beams (24mm battens)
Many thanks in advance for your help.
Johnny77
Johnny77
