ᐅ 200 m² single-family house for 4-5 people without a basement on a narrow lot
Created on: 7 Sep 2019 18:07
hausbauer
I’m looking forward to your opinions on this design.
Thanks in advance for your suggestions!
Plot size 525 m² (5650 sq ft), 17 m (56 ft) narrow along the street at the south end x 31 m (102 ft) long north-south orientation
Land is completely flat
Site coverage ratio 0.4
Floor area ratio 0.8
Building envelope, building line and boundary each 5 m (16 ft) from the street at the south and from the northern border
Edge development
Number of parking spaces 2
Maximum height / limits 8 m (26 ft) total height (attic will be quite low)
Basement, floors 2 full floors without basement
Number of people, age 2 adults + 2 children (currently small) + possibly a third child
Room requirements on ground and upper floor 2 children’s rooms, 1 office/guest room large enough to be another children’s room, 1 additional small office, guest bathroom with shower, open living-dining area
Office: family use or home office? Only for work after hours and weekends, as well as for taxes etc.
Number of overnight guests per year few
Open or closed architecture
Balcony, roof terrace no
Garage, carport Double garage would be good, but probably won’t fit?
Utility garden, greenhouse no
Other wishes / special features / daily routine, also reasons why some things should or shouldn’t be included
Bedroom facing north for a clear view; no north-facing garden because it would be too dark in autumn/winter due to shading from surrounding houses; overall, lots of natural light in the living areas is very important to us
Enough usable space and storage inside the house (large utility and service room), since we don’t have a basement and there is no room on the plot for large garden sheds
Who designed it: self-designed based on a template
What do you like most? Why? Layout of the upper floor (nice children’s rooms with south and southwest orientation, bedroom facing north, large utility room), possibility of a second terrace on the north side by the guest room for shade and view north in midsummer
What do you not like? Why? Entrance area on the ground floor is a bit narrow, otherwise we’re quite inexperienced with what might work well or not in everyday life.
If you had to compromise, on which details or expansions
-You could do without: large hallway areas, if necessary a half-landing staircase (instead of more space-consuming stairs), if needed a pantry next to the kitchen (could be replaced by space under the stairs), a structural requirement might mean adding an extra partition wall in the utility room (which could also be used as a room divider for more storage space)
-You cannot do without: south-facing living-dining area, enough space for bicycles etc. on the property (currently a bit tight)
Questions about the floor plan:
- Is the plot well used?
- Is the entrance area too narrow at 175 cm (69 inches)?
- Are the rooms arranged practically for a family of 4 to 5?
- Do we have enough storage given that we lack a basement and the attic is quite low?
- Is it a big disadvantage in terms of sound transmission that the two children’s rooms share a common wall?
Note: The entire plan will be revised by a professional once we are happy with the overall layout. Then dimensions will be more precise, drawings nicer, and structural calculations reliable. I’m just interested in early feedback on potential weak points and good alternatives.
Floor plan of a house with kitchen, living room, guest room, terraces and garden.
Floor plan of a house with guest room, living room, dining area, kitchen, pantry, WC, shed and stairwell.
Floor plan: bedroom 18 m² (194 sq ft), bathroom 13 m² (140 sq ft), office 10.1 m² (109 sq ft), utility room 10.3 m² (111 sq ft), children’s rooms 16.2/16.1 m² (174/173 sq ft), hallway.
hausbauer
30 Sep 2019 12:48
kaho674 schrieb:
If both partners get up at the same time, you could swap the bedroom, bathroom, and dressing room in a circle to save some hallway space. Bathroom then around 10m² (108 sq ft) – allowing for a generous bedroom:
Wow, that’s an interesting alternative as well, thank you very much! Which software did you use for this, by the way?
kaho67430 Sep 2019 14:53
I find the layout on this small plot completely unsuitable.
I would double-check the need for all these rooms. Is there really a need for both a guest room and an office at the same time? Over 11m² (120 sq ft) just for technical equipment and then another equally large space for laundry – seriously?
Does the development plan actually allow for 2 full floors plus an attic? Maybe it would be better to use the attic as future expansion space in case a third child really comes, and make do with less space for now?
You also have to consider that everything needs to be maintained. We had plans for 2 children as well and now have over 170m² (1,830 sq ft). Unfortunately, it didn’t work out with the kids. I have to admit now that we actually have 2 rooms left unused. Apart from heating, they still need to be cleaned. That can get really annoying sometimes. Losing garden space for more rooms would not be an option for me, especially on just over 500m² (5,380 sq ft).
Has the budget already been mentioned?
hausbauer
30 Sep 2019 17:42
Thanks for the good advice!
Unfortunately, adding a convertible attic space isn’t an option; otherwise, we would have gone that route. We simply don’t want to give up on having a third child just because the house is one room too small. Of course, the spare office upstairs might be "extra" if child number 3 doesn’t arrive.
Larger plots were unfortunately all sold out. Although we would have preferred to buy a smaller one with the possibility of a basement. But you take what you can get.
It’s clear that the house is ultimately too large for the plot, but neither of us wants a very big garden. Perhaps the current cramped space in our 74m2 (800 sq ft) apartment for four people is the trigger for us now to go completely in the other direction…
kaho67430 Sep 2019 18:42
Hausbauer schrieb:
Unfortunately, an expandable attic is not possible,
What do you mean by "not possible"? What exactly does the zoning plan say?
Hausbauer schrieb:
Of course, the house is ultimately too large for the plot, but neither of us wants a very big garden.
That will probably change, trust me.
Hausbauer schrieb:
Maybe the current cramped space in our 74m2 (800 sq ft) apartment with four people is the reason we are now going completely in the other direction...
I’m a bit worried about that. What is your budget?
hausbauer
30 Sep 2019 18:49
kaho674 schrieb:
What do you mean by "not allowed inside"? What exactly does the zoning plan say?
Maximum height is 8 m (26 feet) – so you can only stand in the middle of the pitched roof.
kaho674 schrieb:
That will change, trust me.
Maybe. Right now, for me, it's already a big step to "accept" having a garden with all the work that comes with it…
kaho674 schrieb:
I’m a bit worried. What is your budget?
It’s a bit like going grocery shopping while hungry – the cart ends up fuller than usual.
The budget is sufficient for what has been offered to us as an estimate. For a comparable 140–160 m² (1,500–1,700 sq ft) house with a basement, the costs would be similar.
rick201830 Sep 2019 20:47
And what kind of estimate is being offered, or what is the budget?
For 200m² (2,150 sq ft) in Bavaria, you’re looking at around €500,000 plus additional construction-related costs, garage, exterior landscaping, and interior fittings. This is without any significant custom requests...
