ᐅ 12 x 9.6 m, 2 full stories, basement, attic, 4 children's bedrooms
Created on: 26 Apr 2018 22:24
Johannes L
After more than six years of searching, we will soon be able to purchase a plot of land, so it’s time to advance the planning.
Since we are still undecided whether to build with an architect or a developer, we started drawing ourselves and have been diligently browsing internet forums like this one. The floor plans below are the result, thanks to SketchUp.
I hope we understand the floor area ratio correctly, meaning the basement is not included. Otherwise, we have a problem...
Development plan/restrictions
Plot size 15.6 x 29.95 m = 436 sqm (51.2 x 98.3 ft = 4,692 sq ft)
Slope no
Site coverage ratio 0.4 = 174.4 sqm (1,878 sq ft)
Floor area ratio 0.8 = 348.8 sqm (3,753 sq ft)
Building envelope, building line and boundary 12 m depth (39 ft)
Setbacks 3 m (10 ft) on right and left
Number of parking spaces only in front of the garage planned
Number of storeys 2 full storeys
Roof type Gable roof 42 degrees
Style brick + Wienerberger Poroton T7 P 36.5
Orientation garden facing east-northeast
Maximum height restrictions 10 m (33 ft) high
Other requirements finished floor level at least 30 cm (12 inches) above reference mark
Client requirements
Style, roof shape, building type gable roof is mandatory
Basement, number of storeys 2 full
Number and ages of occupants 6 (37, 36, 6, 4, 2, 0)
Space requirements on ground and upper floors (see plan)
Office: family use or home office? both
Guests sleeping per year the attic provides enough space
Open or closed architecture
Traditional or modern design it will be a smart home with KNX, photovoltaic system, heat pump, possibly battery storage…
Open kitchen, kitchen island open kitchen
Number of dining seats 6
Fireplace no
Music/stereo wall I was thinking of multi-room audio, i.e. one ceiling speaker per room
Balcony, roof terrace no
Garage, carport garage
Utility garden, greenhouse later
Additional wishes/particulars/daily routine, also reasons why certain things are required or excluded The house should be divisible in 25 years, hence the staircase placement. There is a kitchen shown on the upper floor, but it will only be relevant in 25 years. I roughly marked the ventilation system, indicating where ceiling or wall outlets might be and where ducts lead to the upper floors. The two offices are important. The master bedroom on the ground floor is future-proof. Everyone gets old!
Who designed the plan: us amateurs
What do you like most? Why? four equally sized children’s rooms
What do you like least? Why? the upstairs hallway might be somewhat dark
Price estimate according to architect/planner: if only we knew
Personal price limit for the house including fittings: 400 + building allowance
Preferred heating technology: ground-source heat pump
If you have to give up features or extensions
- what can you do without: I hope we don’t have to
- what can you not do without: we definitely want to keep the base dimensions and the basement is a must, but we may have to save on components.
Why is the design like it is now? 4 children’s rooms, two offices, ground floor master bedroom, divisibility in 25 years…
What do you think makes it particularly good or bad? that’s what we want to know from you
What would you do differently and why?
kaho6747 May 2018 09:04
Johannes L schrieb:
.. since the basement and attic are not intended to be finished, and the rest largely depends on the materials used.
What do you mean by “finished”? That it’s not a living room? But you still have electrical wiring, moisture insulation, plaster on the walls, and possibly a floor with some kind of covering. Little by little...
haydee
7 May 2018 09:21
450,000 definitely isn’t enough for the house and the wishes listed at the entrance. Even with a simple finish, I see a 5 in front of the price. With 4 children, there isn’t much room for doing work yourself. And what do you really save if you spend your annual vacation time installing the floor coverings yourself?
Enclosed volume costs money.
I would separate the building services and the utility room (laundry). When I think about the humidity in our room when the washing machine and dryer are working on heavily soiled laundry, I can’t imagine that is good for the equipment in the long run.
When a service technician, chimney sweep, or others come by, it also looks tidier right away. With 6 people, you end up with quite a pile of laundry.
Johannes L
7 May 2018 09:51
The technical equipment and laundry area are connected to the exhaust of the controlled residential ventilation system. Therefore, there should actually be no moisture problem (even if it is a shared room), even when laundry is hung there to dry, right?
haydee
7 May 2018 10:10
They are connected. Still, the exhaust air isn’t removed effectively while the dryer and washing machine are running. It just takes a bit longer. Maybe it’s less noticeable in a larger room.
You have space, so why not separate them properly?
