ᐅ 12 x 9.6 m, 2 full stories, basement, attic, 4 children's bedrooms
Created on: 26 Apr 2018 22:24
Johannes L
After more than six years of searching, we will soon be able to purchase a plot of land, so it’s time to advance the planning.
Since we are still undecided whether to build with an architect or a developer, we started drawing ourselves and have been diligently browsing internet forums like this one. The floor plans below are the result, thanks to SketchUp.
I hope we understand the floor area ratio correctly, meaning the basement is not included. Otherwise, we have a problem...
Development plan/restrictions
Plot size 15.6 x 29.95 m = 436 sqm (51.2 x 98.3 ft = 4,692 sq ft)
Slope no
Site coverage ratio 0.4 = 174.4 sqm (1,878 sq ft)
Floor area ratio 0.8 = 348.8 sqm (3,753 sq ft)
Building envelope, building line and boundary 12 m depth (39 ft)
Setbacks 3 m (10 ft) on right and left
Number of parking spaces only in front of the garage planned
Number of storeys 2 full storeys
Roof type Gable roof 42 degrees
Style brick + Wienerberger Poroton T7 P 36.5
Orientation garden facing east-northeast
Maximum height restrictions 10 m (33 ft) high
Other requirements finished floor level at least 30 cm (12 inches) above reference mark
Client requirements
Style, roof shape, building type gable roof is mandatory
Basement, number of storeys 2 full
Number and ages of occupants 6 (37, 36, 6, 4, 2, 0)
Space requirements on ground and upper floors (see plan)
Office: family use or home office? both
Guests sleeping per year the attic provides enough space
Open or closed architecture
Traditional or modern design it will be a smart home with KNX, photovoltaic system, heat pump, possibly battery storage…
Open kitchen, kitchen island open kitchen
Number of dining seats 6
Fireplace no
Music/stereo wall I was thinking of multi-room audio, i.e. one ceiling speaker per room
Balcony, roof terrace no
Garage, carport garage
Utility garden, greenhouse later
Additional wishes/particulars/daily routine, also reasons why certain things are required or excluded The house should be divisible in 25 years, hence the staircase placement. There is a kitchen shown on the upper floor, but it will only be relevant in 25 years. I roughly marked the ventilation system, indicating where ceiling or wall outlets might be and where ducts lead to the upper floors. The two offices are important. The master bedroom on the ground floor is future-proof. Everyone gets old!
Who designed the plan: us amateurs
What do you like most? Why? four equally sized children’s rooms
What do you like least? Why? the upstairs hallway might be somewhat dark
Price estimate according to architect/planner: if only we knew
Personal price limit for the house including fittings: 400 + building allowance
Preferred heating technology: ground-source heat pump
If you have to give up features or extensions
- what can you do without: I hope we don’t have to
- what can you not do without: we definitely want to keep the base dimensions and the basement is a must, but we may have to save on components.
Why is the design like it is now? 4 children’s rooms, two offices, ground floor master bedroom, divisibility in 25 years…
What do you think makes it particularly good or bad? that’s what we want to know from you
What would you do differently and why?
Arifas6 May 2018 23:13
We also found visits to IKEA helpful. At least in our case, the square meters of the rooms are indicated there, which gives a good sense of the size. Additionally, you can see affordable and practical furnishing ideas, which also provides inspiration for designing the rooms and should, in turn, influence the floor plan.
Johannes L
7 May 2018 07:36
Hello Arifas,
great idea. However, I’m not sure if this is the same at all IKEA stores. I’ll have to check it out sometime.
In the meantime, I have revised the floor plan a bit. I’m still not sure if the technical room and laundry room could perhaps be combined into one. That might have advantages for positioning the appliances and routing the pipes.
2D floor plan of a building with stairs, entrance area and dimensions
Floor plan of living and kitchen area with island, cupboards, stairs and furniture.
Site plan of a plot with building floor plan, dimensions and colored marking
Floor plan of a building section with storage, workshop & co, corridor, utility room, technical room and laundry.
Floor plan of a building section: storage, workshop, utility room and laundry/technical with stairs.
Technical building plan of a house with roof tiles, windows and dimension lines
Floor plan of a house: kitchen, living room, stairs, 4 children’s rooms (Child1–Child4); dimensions
Front view of a two-story house with pitched roof, windows and dimensions.
Architectural drawing of a house with tiled roof, facade windows and floor plan lines.
Technical front view of a house with roof, windows and dimensions.
kaho6747 May 2018 07:58
I roughly estimate this design to cost around 550,000 euros. What do you think?
Johannes L
7 May 2018 08:23
Hi Katja,
Without having done the preliminary verification yet, I expect less since the basement and attic will not be finished, and the rest largely depends on the materials used.
Ibdk147 May 2018 08:25
I can’t comment on the costs, but I don’t understand the discussion about the guest toilet. You can easily make the guest toilet a bit wider if you move the toilet in the main bathroom to the right. Isn’t there still space, or am I missing something?
Johannes L
7 May 2018 08:31
Basically it’s possible, but I would reduce the size of the wardrobe... and I truly believe that you don’t need more space... though of course opinions differ.
Ibdk14 schrieb:
I can’t comment on the costs, but I don’t understand the discussion about the guest toilet. You can easily make the guest toilet a bit wider if you shift the toilet in the bathroom to the right. There should still be room, or am I missing something?
