BMwuppdich15 Jul 2021 18:34Good evening everyone,
I would like to cover an 11.5 cm (4.5 inches) load-bearing wall with gypsum fiberboard panels.
My plan is to attach wooden slats to the existing wall, screw the gypsum fiberboard panels onto them, and then fill and wallpaper.
The reason is that I need to install wiring inside this wall, and I have recently learned that it is not allowed to chase channels horizontally into an 11.5 cm (4.5 inches) wall.
My main question: Can I simply install wooden battens in front of the wall and then mount the gypsum fiberboard panels on them? Or would the 2–3 cm (about 1 inch) gap in between eventually cause mold or similar issues?
BMwuppdich15 Jul 2021 19:01Correct. But unfortunately the interior wall is load-bearing 😉
Thank you
Thank you
You probably want to use drywall panels and electrical wiring in "smart mode on," which works well as described. If you also want to improve the poor sound insulation of your 11.5cm (4.5 inches) wall, you can achieve this by installing a separate drywall partition in front of the existing wall using suitable profiles.
BMwuppdich15 Jul 2021 19:06i_b_n_a_n schrieb:
You probably want to install "smart mode on" drywall panels and electrical wiring, which works well as described. If you also want to improve the poor sound insulation of your 11.5cm (4.5 inches) wall, you can achieve this with a detached, added drywall partition (using appropriate profiles).I have to agree with you... Of course, it will be drywall panels and electrical wiring 😉
I had already read about the detached wall. However, every millimeter (every inch) counts in this room 😉
