ᐅ 10 kW / 35 kW Heat Pump, Cost-Effective Choice for a Heating System with Heat Pump?
Created on: 4 Apr 2009 17:05
Mackk
Mackk
4 Apr 2009 17:05
Hello
I am planning to replace my standard central heating system with a heat pump to reduce costs. My house is about 200 m2 (2,150 sq ft), and I am not sure how much power I would need to heat it during the winter. As far as I know, heat pumps range from 10 kW to 35 kW.
Thank you in advance for any advice.
JOERG24
14 Apr 2009 13:44
I assume you will need the same kW rating later as you do now—unless you also make changes to the insulation.
A heat pump mainly makes sense if you have low supply temperatures.
