ᐅ Is it possible to retrofit IKEA BRIMNES drawers with a soft-close mechanism?
Created on: 20 Jun 2018 14:43
BAULOHello everyone,
I have a question about retrofitting the soft-close feature on IKEA Brimnes drawers.
The BRIMNES series is actually very practical and affordable, but unfortunately, the drawers don’t have any damping when closing.
Now I’m considering whether it’s possible to add this feature afterward without completely replacing the drawer slides or dismantling the furniture extensively.
Specifically, I’m interested in whether there are suitable soft-close mechanisms that can be easily mounted onto the existing drawer slides, how complicated the modification is, and if there are any experiences regarding the durability of such retrofits.
Maybe someone here has already done this or knows a good solution?
Thanks in advance for your advice!
BAULO schrieb:
whether this feature can be added afterwards without completely replacing the drawer slides or having to extensively dismantle the furniture.That usually isn’t possible because the BRIMNES drawers use simple roller runners. Soft-close mechanisms generally require special rails.
BAULO schrieb:
whether there are suitable soft-close mechanisms that can simply be mounted onto the existing drawer slidesSuch universal retrofit kits are rare or not suitable for BRIMNES.
My advice: if possible, switch to soft-close slides from IKEA or third-party manufacturers.
I think it’s important to first clarify what exactly is meant by “soft-close.” The technology can work in different ways: some systems automatically pull the drawer gently closed, while others only dampen the last millimeter.
That’s true, but I wonder if it might be possible to use an additional damper that attaches to the existing slides. Such devices do exist for other types of furniture.
However, I haven’t seen any proof that this would work with BRIMNES, since the slides there are quite slim and minimalist.
I also wonder if a fundamental alternative would be to replace the entire drawer slides with soft-close versions and retrofit them. Although more labor-intensive, this would offer a reliable and long-lasting solution.
Has anyone checked how much effort and cost a complete retrofit would involve compared to just adding a damper? Or are there any attempts to make such hybrid solutions work?
glamo8 schrieb:
Soft-close mechanisms usually require special drawer slides.
BAULO schrieb:
Maybe someone here has already done this or knows a good solution?I just wanted to let you know that I was in a similar situation and had to patiently try out what really works. I didn’t fully retrofit my BRIMNES drawers, but got external dampers that can be mounted on the drawer front and the furniture frame. Unfortunately, this doesn’t close quite as smoothly as integrated soft-close slides, but it has the advantage that you don’t have to replace the drawer runners.
The downside is that some dampers lose their effectiveness over time or don’t always fit perfectly. Installation can also be tricky in tight spaces.
I would carefully weigh the effort involved. If you want a mostly inexpensive but retrofittable soft-close option, these external dampers are worth considering. If you prioritize maximum comfort and a clean interior, a complete replacement set of soft-close drawer slides is worth it.
It also depends on how often and intensively the drawers are used. For heavy use, I think a solid solution makes more sense.
I hope this helps!
