ᐅ Is a tile height of 2 meters (approximately 6.5 feet) sufficient in a shower?
Created on: 23 Jun 2015 22:15
willWohnen
willWohnen
23 Jun 2015 22:15
we have an enclosed, open shower with an almost level-access shower tray.
The L-shaped wall surrounding the shower tray is about 2.10 meters (6 ft 11 in) high.
No one remembers why it is 2.10 meters (6 ft 11 in)!
No idea if we ever discussed this with anyone. Anyway.
The tiler wants the bathroom and the inside of the shower tiled to the same height, 2 meters (6 ft 7 in). So that the bathrooms are tiled "all the way up," which we wanted—I know, I know, nowadays it’s more common to tile as low as possible...
The actual question: Is 2 meters (6 ft 7 in) tile height in the shower enough?
My husband always showers with thin high-pressure jets, so he almost looks like a sparkler!
willWohnen
kbt09
23 Jun 2015 22:50
My shower partition walls are also about 210 cm (83 inches) high. However, they are fully tiled all around, including on top.
It is important to consider at which heights full tiles should start and at which heights, for example, around sinks, the tiling should continue. I like continuous grout lines and also appreciate that in my tiling, for instance, it started below the window with the large tiles extending outwards from the center to the right and left.
My bathroom is only 4.2 square meters (45 square feet) in size, so it is difficult to photograph.
Badezimmer im Bauzustand mit Dusche, Fliesen, Fenster und Eimer auf dem Boden.
Badezimmer-Spiegel, rosa Handtuch am Heizkörper, Tissue-Box, florales Muster.
Badezimmer mit Fenster, Jalousie, großem Spiegel, Waschbecken und rosa Handtuch.
23 Jun 2015 23:15
willWohnen schrieb:
So that the bathrooms are tiled “all the way up,” that’s what we wanted,
Yes, then just tile all the way up
@kbt09 nice mirror wall
kbt09
23 Jun 2015 23:17
Custom-made .. turns 4 m² (43 sq ft) into almost 6 to 8 m² (65 to 86 sq ft)
f-pNo23 Jun 2015 23:22
willWohnen schrieb:
The real question: Is 2 m (6 ft 7 in) tile height in the shower enough???
My husband always showers with thin high-pressure streams, so he almost looks like a sparkler!
It depends on two factors.
1. How tall are you? For heights between 1.50 and 1.70 m (4 ft 11 in and 5 ft 7 in) 2 m (6 ft 7 in) can be sufficient.
2. How do you shower? Based on your description of your husband’s shower style, you should tile up to the full 2.10 m (6 ft 11 in).
3. I think it would look odd if the last 10 cm (4 in) suddenly were not tiled. Also consider the advice from @kbt09 – tile above the height as well.
Edit: You want to live there for the rest of your life (or at least many years). If it’s not financially impossible, it should be 100% to your liking. One or two extra square meters (square yards) of tiles should not be a financial issue.
lastdrop24 Jun 2015 07:06
Yes, tile the entire surface, including the top. I didn’t do that, and it’s annoying because it really collects dust.
