ᐅ Flat Roof – What Are Your Experiences and Would You Do It Again?
Created on: 9 Jun 2015 22:57
X
xycrazy
X
xycrazy
9 Jun 2015 22:57
We are in the final stages of negotiations and have decided on a flat roof that will need to be extensively greened.
There isn’t much positive information about flat roofs, although most reports date back to the 1960s and 1970s. I assume this issue has largely been resolved by now.
Still, I’m curious if anyone here has built a flat roof or purchased a house with a flat roof and what your experiences have been. Would you choose it again? Any problems? How do you maintain the roof? And how is maintenance done on a green flat roof?
Thanks a lot!
X
xycrazy
11 Jun 2015 13:04
Has no one had any experience?
Bauexperte
11 Jun 2015 13:16
But I do, quite a lot. However, this probably isn’t the information you were hoping to hear.
Regards, Bauexperte
Bieber0815
11 Jun 2015 19:28
xycrazy schrieb:
How is maintenance usually done on a green flat roof?
I'm not an expert, but... An extensive green roof should be inspected once or twice a year. During this, you remove any unwanted plants and ensure that the drainage system is clear and functioning properly. That’s basically it.
Otherwise, I consider flat roofs to be no big issue nowadays if they are installed correctly. Even more so when they are green!
bernie
11 Jun 2015 19:36
Bieber0815 schrieb:
Otherwise, I consider flat roofs to be no major issue today if professionally installed. Especially when they are green roofs!
I guess my bosses thought the same.... but unfortunately, at our workplace, the flat roof leaks every 2 years and the contractors have to come...
I’m not an expert either... but my gut feeling tells me that a flat roof will eventually develop leaks sooner or later.
Bieber0815
11 Jun 2015 20:11
Countless other flat roofs demonstrate that it can also be made watertight.
