we have a new multi-family house with a heating system, air pump, solar thermal system, and water softener installed.
1- Should these systems be serviced regularly (annually)?
2- What would the approximate cost of such maintenance be?
Sebastian798 Jun 2015 15:15What kind of monster is that 🤨? I need to check for ours right now. Didn’t I have 2kg (4.4 lbs) in mind...
Maintenance of the system by a professional company is definitely a good idea.
We pay a net amount of 200 per year with a maintenance contract. Of course, you can do everything yourself – but you can also leave it to the professionals. For our system, maintenance during the first 2 years was mandatory to extend the warranty to 5 years.
Maintenance also includes professional cleaning. Comparable to the dentist – some people have regular check-ups and cleanings, others don’t...
Sebastian798 Jun 2015 15:26You have a direct expansion system? Yeah, a large one even – you need to do that then. I assumed you had a brine heat pump – sorry.
@Wastl: Also direct expansion or brine?
Lexmaul79 schrieb:
@Wastl: Also brine or direct expansion (DX)?No, I have a standard air-to-water heat pump with integrated controlled ventilation and heat recovery.S
Sebastian799 Jun 2015 09:18OK, so this refers to the filter replacement of the mechanical ventilation system with heat recovery, cleaning of the intake, etc. – all tasks that are not required with a simple ground source heat pump.
I emphasize this only because different things are often mixed up here.
