ᐅ Bathtub filler integrated into the rotary handle?
Created on: 15 Feb 2015 00:43
willWohnen
as you can see from my sink question today, we have returned to the final bathroom planning stage.
For our bathtub, the recessed basin area is slightly angled relative to the wall—no need to picture it exactly—meaning it’s challenging to position a faucet on the wall so that water flows directly into the basin below without obstruction.
In our tub’s case, it would also be possible for water to come out on the side facing away from the wall through this rotary knob that is normally used to close the tub.
Actually, this would be an elegant solution for us, and I imagine the water inflow would be much quieter this way.
Is there any reason against this? Would it be unhygienic or should we worry more about the hose in the tub leaking?
Regards
lastdrop17 Feb 2015 09:14
Yes, we also have foam
EveundGerd17 Feb 2015 09:43
We didn’t have any issues with foam either. It mostly depends on the bath additive.
If necessary, you can use the shower hose to help. That way, you get a great amount of foam.
f-pNo17 Feb 2015 10:15
willWohnen schrieb:
Hehe, thanks @f-pNo.
I could also imagine that it depends on the type of bathtub. There have been reports of different inlet noises. Well, it’s probably hard to test that in advance, so I’ll have to take the risk. Otherwise, there’s always a battery-operated hand blender, and then I can foam up my bath myself.
If it depends on the bathtub type – we have an acrylic bathtub.
EveundGerd17 Feb 2015 10:45
f-pNo schrieb:
If it depends on the type of bathtub – ours is acrylic.
Ours was also acrylic.
Naddl
17 Feb 2015 13:22
Enjoy your shower!
Naddl
17 Feb 2015 13:24
Enjoy your first shower!
