ᐅ Bathroom Lighting: Recessed Spotlights or Central Ceiling Fixture?
Created on: 27 Dec 2025 20:19
Astrid74
Astrid74
27 Dec 2025 20:19
I am currently planning the lighting for my bathroom and could really use your advice.
The mirror lighting is already decided, but now I need to consider whether to add recessed ceiling spotlights or a central ceiling light.
My questions:
  • Which option is more practical for providing even lighting in the bathroom?
  • Are there specific placements or tips you would recommend?
  • What should be considered when combining these with fixed mirror lighting?
I would really appreciate your experiences or suggestions!
Thank you in advance!
Draufsicht 3D-Bad mit Dusche, Badewanne und Doppelwaschbecken in modernem Design.
3D Badezimmer-Render mit Badewanne, rosa Mosaikfliesen und grauen Wandfliesen
27 Dec 2025 22:26
Astrid74 schrieb:
Are there any specific placements or tips you would recommend?
A ceiling light positioned in the center has proven effective for decades.
Astrid74 schrieb:
What is more practical for evenly lighting the bathroom?
Since the bathroom is quite a straightforward rectangular shape, you don’t really need to worry about achieving perfectly even lighting.
Astrid74 schrieb:
What should be considered when combining it with fixed mirror lighting?
They should be switched separately.
And: I hope you keep all your bathroom questions in one post, just as the renovation is best done in one go.
motorradsilke
27 Dec 2025 22:31
We have it the same way as @ypg described. The ceiling light is centered and can be switched independently from the mirror cabinet lighting. This setup has proven effective over the past 4 years. Since the shower has glass walls, this works well; with built walls, I would do it differently. Spotlights would be too inflexible for me.
Astrid74
27 Dec 2025 22:44
motorradsilke schrieb:
We have it the same way as @ypg describes. The ceiling light is centered and can be switched separately from the mirror cabinet lighting. This setup has worked well for four years. Since the shower has glass walls, it works fine; with masonry walls, I would do it differently.
Thank you for your answer, very helpful!!!
Astrid74
27 Dec 2025 22:46
A centrally placed ceiling light has proven effective for decades.
Since the bathroom is quite a simple rectangular shape, you don’t really need to worry about achieving even lighting.
Switchable separately.
And: I hope you reconsider and keep all bathroom-related questions in one post, just as the renovation is done all at once.
Thank you, you helped me a lot. I had actually planned it that way already, but a lighting consultant confused me completely today… thank you.
27 Dec 2025 22:50
Astrid74 schrieb:
Thank you, you really helped me. I had actually planned it that way anyway, but a lighting consultant really confused me today…. thanks
The lighting consultant probably wanted to earn more than just from one ceiling light.
